Had no idea
LsRedy2Kstang said:
It has not gone to track beast yet. The car is stock if you would have read the post! I see that you just scanned! Man o Man!
YOu coming to the drag day on the 24th? YOu should it will be fun whipping up on you with the V6!
Travis
Nope, probably not. It's quite a far drive just to go to the track and I don't plan that far ahead really :) I'm still trying to pass calculus....we have our 2nd exam tomorrow and I really don't know the material.
decoy562 said:
WTF do you need a third car for if you're still in college?!?
Dirt track racing :) Besides, when I rip the interior out (depending on the shape of the interior) I can part it out. All I need is the steering wheel, driver's seat, shifter and speedo/tach. Everything else goes bye-bye.
Moldings, dash trims, seats, glass, trunk pieces and exhaust all go bye-bye :)
Na, the one I thought I found was a 6 cyl....the guy I pit crew for though has a brother that's gonna get one though from his uncle. So I'll probably just help him race (and he'll probably let me race).
Yeah, has to have a 4 cylinder.
http://www.centralalabamaspeedway.com/sys-tmpl/ponyrules/
(1)- CARS: Any 2 or 4 door(passenger) sedan, station
wagon or mini-truck, between 86 and 102" wheelbase, no 4-wheel
drives, no rear engines
(2)- ENGINES AND DRIVETRAIN: Engine must be factory stock for make
and model of car, in stock position ENGINE SIZE: Max. O.E.- 2500
c.c.
stock type piston, stock stroke crank, stock length rods, must be
self starting. Factory stock carb. or may run with adaptor max. 500
C.F.M.2 barrel or unaltered(except for removal of choke
plate).Stock fuel pump, No fuel injection or turbos, stock intake,
headers allowed, No porting or polishing of head, valves must
remain stock size, heads may be shaved, no roller cams or
followers, Stock trans(auto or man.), stock rear-ends(may be
locked)
No aluminum flywheels, Stock clutch and pressure plate, must have
inspection hole in flywheel cover.
(3)-WHEELS-8" steel
(4)-BODY- Full stock bdy, must retain full firewall and floorpan,
may run stock nosepiece and tailpiece
(5)-WEIGHT- Min. Wt.- 1600 lb.
Front wheel drives- 2000 lb. min. wt.
Ford 2300 c.c.- 2200 lb min. wt.
all other cars 1 lb. per c.c.
all weights with driver at any time
(6)- BRAKES- Stock
(7)- SUSPENSION- stock type suspension required in stock location,
may be rinforced. 1 shock per wheel in stock location-, no
jackbolts
ALL ROLLCAGE AND SAFETY REQUIREMENTS APPLY
