Hanging Idle
Discussion in 'Mach 1' started by twogts4us, May 3, 2008.
  1. twogts4us Advanced Member
    Apr 2, 2004
    Message Count:
    4,084
    68
    Yep, that's the problem, a hanging idle, especially when it's cold - any fixes? This is on my new ride, a 2004 Mach 1. I just got done installing (and then removing) an IAC restrictor plate (homemade gimmick, using two holes, one was the standard size, the second one, on the pass side of the IAC, was smaller, about 9/32", (all cut and drilled as described in an article here on StangNet). It seemed to drop the idle quicker in between shifts, but the idle, both cold and warm, was worse than ever...hanging around 1500 RPMS!
    Help!
  2. hotrodnut Member
    Jul 12, 2004
    Message Count:
    672
    I have it too, I have the IAC plate installed, diablo tune like yours but it still hangs, It usually hangs at about 1000-1100 though for a few seconds before dropping to normal idle speed.
    It's bugs me that it does it, I wrote to diablo a long while ago asking if they could send me a tune that would eliminate it but never got an answer so I assumed they couldn't.
    When I drive the Mach steady for several miles and come to a stop it doesn't happen, but short trips and rips around town it always hangs.
  3. Mach1Run New Member
    Jun 25, 2004
    Message Count:
    417
    Mine hangs once in a blue moon but that was a known issue with the accufab TB i installed I believe.
  4. hotrodnut Member
    Jul 12, 2004
    Message Count:
    672
    There was a SPECIAL SERVICE MESSAGE dated in 2003 that said that some Mustang Mach1s may have an intermittent high idle. It was caused by a damaged wiring harness that was on the left side near the rear of the transmission crossmember and mount. I think it was the connector or something rubbing.
Share This Page
