Head torque ???
Discussion in '94-95 Tech' started by Daves94vert, Dec 28, 2003.
  1. Daves94vert Founding Member
    Jan 3, 2001
    Message Count:
    108
    What are the torque specs for aluminum heads? What do you use on the threads to read torque? I'm using ARP head studs on tfs tw heads.
  2. VibrantRedGT "STANGNET'S PENGUIN SMACKER"
    Sep 6, 1999
    Message Count:
    13,759
    25
    98
    I did 80 ft lbs up top and 85 ft lbs on the bottom bolts. Make sure they are done in the right sequence. Start in the middle and work your way outward.
  3. ponyboy19 Founding Member
    May 24, 2000
    Message Count:
    1,737
  4. Bling Founding Member
    Jan 17, 2002
    Message Count:
    138
    On mine I've always done 85 on top 80 on the lower row. I use moly lube under the head bolt washers and under the bolts. Start in the middle, in steps from 40ft lbs, 60ft lbs, then 80ft lbs. I then go back and do the top row another 5ft lbs. I usually wait anywhere from an hour to maybe a whole night (depending on the amount of alcohol consumed :D ) then go back and check them all again. Make sure you don't overtorque the lower intake either. I put some thread sealer on the bolts and torque them to 12ft lbs. It'll take 4-5 passes to get them all torqued evenly. Good luck.
  5. blksn955.o Founding Member
    Mar 15, 2002
    Message Count:
    3,262
    66
    Dont forget to put some sealer on the lower bolts since they go into a water jacket, I used some permatex (but I am sure there is a better sealer as permatex is so thick it could mess up trq readings, I just did each side quick so the tex would not get hard).
  6. moneypit94 New Member
    May 23, 2003
    Message Count:
    1,711
    good choice with the head studs... It is worth the little extra money to not have to worry about needing to retorque them again.
    I tryed to retorque my studs and it was just a waste of time...
Share This Page
