Head Workings
Discussion in '94-95 Tech' started by tderrick, Oct 29, 2009.
  1. tderrick New Member
    Oct 28, 2004
    Message Count:
    313
    Would someone explain the workings of the head as per stud mount, pedestal mount, 1.6 vs 1.7 rockers etc.... what I should look for in a head ...
    trying to understand as much as I can for this rebuild... :D
    thanks, as always...
  2. earleys94gt Member
    Aug 31, 2003
    Message Count:
    824
    In short....Pedestal mount are more for stock applications where decking wasn't involved or big profile cams. Easy to install as long as you check the geometry.
    Stud are better for adjusting to changes in the engine. You should you use these if you get into custom cams, large heads etc.
    The 1.6 moves the valve a distance that equals the lift measurement of the
    cam, times 1.6. So the 1.7 opens it a little bit farther.
  3. tderrick New Member
    Oct 28, 2004
    Message Count:
    313
    What is decking and what do you mean by geometry ?? :shrug:
  4. earleys94gt Member
    Aug 31, 2003
    Message Count:
    824
    The geometry is the angle of the pushrod on the rocker arm, the rocker arm on the vavle spring etc.
    Having the geometry right is vital to ensure proper operation of the valve train, and to avoid wear on parts.
    Decking the head means you actually remove some material from the bottom of the head, the part that goes against the block, to "move" the valve closer to the piston. One would do this to either "adjust" compression or to ensure a smooth mating surface against the block.
  5. tderrick New Member
    Oct 28, 2004
    Message Count:
    313
    Got it.... thanks
Share This Page
