Headlight cleaning problems.
DARCA
61
Tacoma, WA
Ok, So I pulled my driver side head, parking, and turn lights off. I am looking inside them and they have quite a bit of crap in there (dirt, bugs, water, etc...). I would like to clean these lights out but poring more water in to them just doesn't sound like a good idea to me. How should I go about cleaning these out?
Also My headlight has a little metal piece that is loose and rattling around inside of it, I am assuming this is a reflector piece that fits in front of the bulb some how. Am I screwed with it being loose or is there a way to get it back in place that is worth doing?
Thanks again for all the help.
-Brad
I have cleaned a lot of these lights. A lot of people would rather throw the stockers out for 6 piece replacements but believe in refurbishing original units provided that they are in good repairable shape. I use compressed air to remove water or debris from the inside of the light and then I wet sand the front of the lenses with 1500 grit sand paper and then follow up with 2000. After the wet sand is done use Meguires Xcratch X or 3M rubbing compound to rub out the sand scratches. You will be amazed and the finish lasts for years not months.
I refurbished the headlights on my old Escort, kind of like 1987stangman said, then I sprayed them with a thin layer of clearcoat and they didnt oxidize again. Be sure to put some clear sealant around your lights so they wont leak anymore.
You'll probably need a new sidemarker housing because of the reflector, its near impossible to try to crack open the lense without breaking it.
by useing sealant on them i would assume it's to seal in the finsh and make it last longer. unless you mean sealant as in resealing where the lights are bonded together? peace
john:p
