Heater not working
Discussion in '94-04 V6 Mustang' started by 94whitestang, Jan 2, 2005.
  1. 94whitestang New Member
    Jan 1, 2005
    Message Count:
    12
    Oregon
    OK so I'm new here and have a 94 mustang v6. The heater does not get hot. I replaced the thermostat, but still cool. I pumped water in the in and out tubes of the heater core, thinking it was pluged. BUt still no luck. So if any of you know what else I could try that would be awsome.
    Tom
  2. Jamez Founding Member
    Mar 2, 2000
    Message Count:
    2,610
    Tulsa, Ok
    Does the car still get up to temp, but the it just blows cold air or is the car also staying cold?
  3. Tru_Blue_104 New Member
    Nov 14, 2003
    Message Count:
    218
    MN
    Ok, i was just having the same problem. Since you replaced the thermostat, did you "burp" the system? There is a bolt on the top-front of the engine (youll know its the vent, it says it right on there), with the engine running, open it very slowly until a little coolant comes out, then close it. ALso, what temp thermostat did you put in? I know I replaced a 195 with a 192, the 195 was old and it let water creep by. Make sure you bought a good one, mine costed $12. I also replaced the Coolant Temperature Sensor (NOT sender). After a few times of running the car from cold to hot, I get nice warm air. I think the main problem though is you have air in the system, get that out, and youll be fine.
  4. 94whitestang New Member
    Jan 1, 2005
    Message Count:
    12
    Oregon
    So the car gets up to temp but it blows cool air still. I put 195 degree thermostat in, but befor we did that we tested it, by boiling it to make sure it would open, and it did. So I'll try burping it and see what happens.
    Thanks
    Tom
  5. Jamez Founding Member
    Mar 2, 2000
    Message Count:
    2,610
    Tulsa, Ok
    Mine blew cold when the thermo stuck open, but the car didn't get up to temp since I was driving all highway at the time. Let us know if removing the air works.
  6. 94whitestang New Member
    Jan 1, 2005
    Message Count:
    12
    Oregon
    Yes, the car gets up to temp but it still blows cold air, so we "burped" it and we'll see if that works. I'll post if it does or not.
    Tom
Share This Page
