Heatexchanger
Discussion in 'Saleen' started by Hollywood03, Jan 31, 2006.
  1. Hollywood03 New Member
    Jan 15, 2006
    Message Count:
    74
    Hey guys...
    How many of you would be interested in upgrading your Saleen heatexchanger to one thats bulit by the people at lightningforce performance it's going to be the same one thats built for the cobra..but will bolt in place on the saleen I'm working with them using mine as a prototype. I dyno my car after installing the heatexchanger ,JLT CAI and Megnaflow XPIPE and made 38 more HP and 40lbs TQ not sure how much the heatexchanger helped but the heatexchanger coolant temp ran about 15-20 deg cooler looks good too..check them out on the web...or call and ask for Mark.
    Thanks
  2. tfalk Founding Member
    Jan 19, 2001
    Message Count:
    1,802
    38
    Under my Saleen or FFR Coupe
    Are you talking about replacing the intercooler-radiator that's under the front fascia or the intercooler that is under the intake manifold? I'd be skeptical of 38 hp from an X pipe, CAI and a radiator change. Gotta be something else going on...
  3. Hollywood03 New Member
    Jan 15, 2006
    Message Count:
    74
    It's the one on the front of the car not under the intake I forgot to add that I was running 96 oct gas.. I did a baseline dyno stock 284 HP 300 TQ (It was hot that day 99+)next dyno was with current mods 323 HP 344 TQ...
  4. Hollywood03 New Member
    Jan 15, 2006
    Message Count:
    74
  5. Friedchicken Founding Member
    Mar 13, 2002
    Message Count:
    497
    Heat exchangers don't increase max hp, but they do alleviate power loss when you encounter a heat soak phase. This can be very important in modified supercharged applications where your tune on the dyno would not apply heatsoak as a factor in your timing/a/f adjustments- so you could dial more boost in safely.
    I got mine for my 03 cobra at www.gordsfordperformance.com
  6. fallstar01 New Member
    Nov 2, 2004
    Message Count:
    54
    I'm interested if they make it so you can attach the fans (my Series IV came with 2 fans on the heat exchanger) and they need to provide the fittings for the saleen hoses. Otherwise, it's a really sharp looking unit.
  7. Hollywood03 New Member
    Jan 15, 2006
    Message Count:
    74
    The fans will fit I have the serries IV also...friedchicken...I thought that if the charge of air thats produced by the supercharger is colder the more H.P. the eng can produce ...
  8. fallstar01 New Member
    Nov 2, 2004
    Message Count:
    54
    it lets you run more timing safely. the timing gives you the power.
  9. Tommy98016 New Member
    Mar 17, 2004
    Message Count:
    90
    New York
    Fried is correct, it slows down the time it takes for heat soak to affect your power.
    If you can get LFP to make you guys a H/E I would get it. I have one of theres on my Cobra and it is a very well made product.
  10. Friedchicken Founding Member
    Mar 13, 2002
    Message Count:
    497
    The heat exchanger can only draw more heat from the structure, it can't lower temps below what the outside ambiant air temp is. You need to go with a bottled application to lower the intake charge temps.
    You deal with 2 issues when you get into aftermarket heat exchangers. Increased capacity, and efficientcy.
    You can have a much larger coolant volume, but that is no good if it doesn't flow fast enough, or too fast depending on how effective your system is at dissipating the heat. If a HE is too thick, air tends to not reach the rear fins and cooling veins. Too thin, and it won't have enough effective cooling area.
Share This Page
