Help...engine coolant leak!
if its from the middle of teh motor you should be able to see something, try cleaning it up really good and then let it run and see ifyou can trace it, the coolant leak areas would be the water pump, radiator hoes where they meet the motor/radiator, the top bolt thats in front of the upper intake that you take off the vent air out of the system, and lower intake edges around the front or back of the motor.
