Help me make my parts list!!!!
Discussion in '94-95 Talk' started by fasterthanthem, Aug 25, 2008.
  1. fasterthanthem New Member
    Mar 30, 2008
    Message Count:
    62
    Hampton, VA
    Alright, I had originally planned on buying the Trickflow trach heat package, but after doing alot of research and saving money I have heard nothing but bad things about this package.
    So far I plan on going with these parts but I need some guidance for best gains.
    COMP cams supercharger cam
    AFR 185cc??? heads
    Trickflow R-series or maybe just track heat intake
    75mm TB
    90mm MAF
    ??# injectors
    1.6RR's
    ARP performance headbolts
    Lots of gaskets
    255lph fuel pump
    What else am I missing?
  2. 4Jenna Founding Member
    Sep 12, 2001
    Message Count:
    4,329
    68
    AZ
  3. fasterthanthem New Member
    Mar 30, 2008
    Message Count:
    62
    Hampton, VA
    The car is already supercharged, It's a completely stock engine right now besides the vortech kit, and msd ignition.
  4. 4Jenna Founding Member
    Sep 12, 2001
    Message Count:
    4,329
    68
    AZ
    Camshaft Innovations or CamMotion (look for 114 lsa)
    AFR 185s (wont work on stock pistons)
    Trickflow R-series or maybe just track heat intake (I would Do the Holley Sys)
    75mm TB (70mm is plenty for a boosted engine)
    90mm MAF
    ??# injectors (42s)
    1.6RR's
    ARP performance headbolts (do studs)
    Lots of gaskets
    255lph fuel pump
    What are you tuning with? Also what pulley combo on the Vortech and does it have a powerpipe?
    Have you done a leakdown on the motor also?
  5. fasterthanthem New Member
    Mar 30, 2008
    Message Count:
    62
    Hampton, VA
    Have not done a leakdown on the motor but I will be taking it to logan motorsports who tunes and uses SCT products. I do have a powerpipe and its running the stock pulley.
  6. BlownFiveLiter have car, will race....wait, it doesn't run
    Oct 23, 2004
    Message Count:
    5,458
    20
    88
    Chicagoland
    With AFR 185cc heads, you may need to flycut the pistons because they won't accomodate a 2.02" intake valve.
  7. fasterthanthem New Member
    Mar 30, 2008
    Message Count:
    62
    Hampton, VA
    What heads would you recommend that would not require any modifications to the pistons?
  8. fasterthanthem New Member
    Mar 30, 2008
    Message Count:
    62
    Hampton, VA
    Anybody? Bueller?.... Bueller?
  9. 4Jenna Founding Member
    Sep 12, 2001
    Message Count:
    4,329
    68
    AZ
    TFS TW they will work with stock pistons
  10. fasterthanthem New Member
    Mar 30, 2008
    Message Count:
    62
    Hampton, VA
    Thank you, you've been a big help!
    BTW: Love the pics of the car in the other thread.. has a mean stance.
  11. BlownFiveLiter have car, will race....wait, it doesn't run
    Oct 23, 2004
    Message Count:
    5,458
    20
    88
    Chicagoland
    As far as I know, the TFS heads are the only ones you can get away with running a 2.02 intake valve on a stock shortblock because of the canted valves. It was one of the deciding factors when I chose to buy them, myself.
  12. 4Jenna Founding Member
    Sep 12, 2001
    Message Count:
    4,329
    68
    AZ
    Thanks man!
    Glad I could help, let me know if you need anything!
    Chris
Share This Page
