OK, I need some help. I've done a lot of research on this issue but what I have found has not helped.
The problem that I have is a vibration when the motor is running. What I have is a E6SE-BA 302 which I believe is a 1986 HO. The harmonic and flywheel are the 50oz versions. I just replaced the 20oz flywheel and the vibration got worse.
What can I do to isolate ot correct the issue?
