Figured I'd get some input for everyone.... I wrote Patrick at CDC about a week and a half ago. Here is some excerpts from the email I got from Patrick, the guy who performed this install.
"...I actually performed the swap without the ’08 smart junction box. Again – keep in mind that the lights I used were pre-production lights direct from Valeo, so I do not believe they are representative of what is available now. The parts I used were not a plug-and-play kit; I had to do some wiring to make everything go together..."
"...I used an additional harness that pulls current from the battery via two relays, and uses the factory headlight wiring as the ‘signal’ to turn on the lights as well as activate the high beams. Nothing else on the car changed, and the lights worked great. I’m trying to track down some additional information about what has changed between the set I installed, and what is available now. As soon as I get any useful information, I’ll be sure to pass it along..."
I also checked with my local dealer and for the headlight assemblies, ballast, etc. it was like $1500 their cost. I decided to stick with Saleen as they go for $900 and everything is included.
I hope this helps and I will post if I receive any more info from CDC.
LB
