HELP!!!
Discussion in '94-04 V6 Mustang' started by ebev, Sep 3, 2004.
  1. ebev New Member
    Jul 1, 2004
    Message Count:
    My car died on me. It doesn't get any spark, the fuel pump won't come on and none of the cluster lights will come on when the ignition is turned on. I replaced the ECU but it still doen't work. Can anyone help me?
  2. atreyu New Member
    Nov 14, 2003
    Message Count:
    44
    Lewisville, tx
    alternator or battory my guess.
  3. dastang2 Active Member
    Dec 12, 2003
    Message Count:
    2,058
    46
    tx
    ok this is one of 2 things. a bad relay that is in your fuse box under the hood, or the harness that plugs into the controller that is screwed to the bracket that is in front of the fan shroud. if that is loose or has dirty connectors, it will not run. check those. oh yeah what year. i am going off of a 98 and under but it should be the same as a a 99 and up car too.
  4. GREENBIOCH Founding Member
    Mar 23, 2002
    Message Count:
    1,247
    In an Igloo
    :stupid: Start with the simple things, I would be replacing your battery right quick as that is what it sounds like to me...and then go from there.
  5. dastang2 Active Member
    Dec 12, 2003
    Message Count:
    2,058
    46
    tx
    that is simple but not the most cost effective. to check the relays and connections is free and a relay can't be more than 5 bucks. i don't see how you don't see any signs of a bad battery before hand. does the engine even turn over. also check the batteries connections and grounds, a lot of folks lately have had this problem too. i know when all my batteries go bad, i get symptoms before hand
Share This Page
