HELPPPPP!!!!!!
Discussion in '2.3L (N/A & Turbo)' started by t3t4_4g63, Jul 2, 2007.
  1. t3t4_4g63 New Member
    Jul 2, 2007
    Message Count:
    94
    i have a few questions for the knowledged 2.3 turbo guys.....ok, im new to the mustangs. i have owned dsm sports cars for a few years now. im 19 years old and i have always liked the fox body style. 2 weeks ago i ran into a guy that has a 1986 svo for sale.... i love the fact that ford made a turbo 4 banger mustang that is very capable of shutting down V8's!!! so i reaserched the car a little and found out some things. but what i really wanted to know is how dependable these cars are?? how often are they known for breaking down?? are they hard to work on?? my dad has a mechanics shop so tools are not a problem... i would just like to know what i would be getting into. i took it for a drive yesterday and all that i can tell is that 2nd gear grinds....easy fix?? it also needs a radiator, battery, tires, corner light and some body work on the front passenger side. the car is completely original!!! he wants $1200 for the car. so please somebody give me some good advise!!! thanks sooooo much!!!!!
  2. kevinspann New Member
    Feb 25, 2006
    Message Count:
    93
    Well they arent really all that hard to work on. In stock form they can be very reliable, a lot of the Turbocoupes (used the same engine with a different turbo) have gone well over 100k miles, and usually end up closer to 150k. And they can last longer than that....if you go to turboford.net, youll learn all you ever need to know. It s best to do searches for information first though, as much of it has been covered.
    Even when they start to be modified a bit they still are fairly reliable, most things that happen are very minor.
    As far as your second gear goes, it sounds like the synchros are getting worn in the transmission, the only cure for it is a rebuild. Or you can just get another T-5 as tehy are rather plentiful, a regular 4cyl t-5 will be fine.
    Radiator and Batteries are easy items. tires of course are easy. They use the same bolt pattern as all 5-lug mustangs, so you can use any of those wheels. The only thing is that the front center cap may not fit. And actually an '05 and up mustang wheel fits better due to its having more backspacing. So if you wanted to go this route, you caould get some takeoff wheels and tires, and then if the SVO wheels were in good shape, im sure you could find someone to buy them
    What kind of front end damage is there? SVO front bumpers are hard to find, and id find out if it had ever been wrecked otherwise
    What color is it, and does it have a sunroof? If you ever want to resell it, these are things that people look for. A rare color without a sunroof is a good thing
    Overall, if the car is in decent shape, and runs and drives well, id say think hard about it, because 1200 really isnt that bad of a price, and hell, you might be able to get him to go lower
  3. 65ShelbyClone Founding Member
    Sep 9, 2000
    Message Count:
    4,527
    66
    1.) No more than a ~20 year old Mitsubishi.....probably less often.
    2.) No more than ANY Mitsubishi, probably easier.
    3.) As easy as it is to change the 2nd gear blocker ring.
    4.) It needs the passenger corner light, doesn't it? Good luck with that. The driver's side is still somewhat available, the passenger side has been obsolete for a decade or longer.
    Despite all that, I'd take a running, driving SVO for $1200. Are you in CA? I'll go get it if you don't.
  4. Red_LX Doubt I could be of much help, unless you need por
    Aug 21, 1998
    Message Count:
    10,471
    78
    Reliability on the 2.3L often points back to maintenance...
    Some people have all kinds of problems.
    I have had virtually zero problems with mine since I rebuilt it 3 years ago (knock on wood), and that was just a basic rebuild reusing several stock parts.
    It's super easy to work on, which is what I love about it.
  5. t3t4_4g63 New Member
    Jul 2, 2007
    Message Count:
    94
    the car has only been i one wreck..... the guy who ownes it now got it from his father 3 years ago when he past away. his dad had it since 1988. he hit "clipped" a deer on the right front corner. its nothing major. i think a little body work will fix it. the hood is also a little dented in the corner....no biggy. the car is dark gray with no sunroof, all leather interior. a.c., power doors and locks, am fm radio(still works). thanks a lot for the help guys!!! if anybody else has any advise or links to were i can find good performance parts please let me know!!! thanks a lot!!!
  6. kevinspann New Member
    Feb 25, 2006
    Message Count:
    93
    man, bumper covers and hoods are kinda hard to find...but otherwise it sounds like a good buy.
    turboford.net
    svoca.com
    stinger-performance.com
    these would all be good places to start looking for ideas/help/parts
  7. t3t4_4g63 New Member
    Jul 2, 2007
    Message Count:
    94
    what small things could i do to this car to get some good hp??how much would it cost??
  8. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Same things as any other turbo car, exhaust, k&n, boost controller, front mount intercooler, etc...cost is cheaper than the mitsu parts. See my sig for some of those items...
  9. t3t4_4g63 New Member
    Jul 2, 2007
    Message Count:
    94
    hey i was looking into buying the stinger front mount intercooler!! what kinds of mods will i have to do to make it fit, if any? and as far as performance goes, does rotating the intake manifold help out at all?
  10. t3t4_4g63 New Member
    Jul 2, 2007
    Message Count:
    94
    im also trying to find a good deap sounding exhaust, can anybody help me out with that?
  11. sleeper_inc New Member
    May 4, 2007
    Message Count:
    92
    It just helps you mount the intercoler piping for a shorter run and less bends. Some people say boost comes on faster.
    Use a 3" or bigger exhaust and make sure its free flowing, not baffled. The new cherry bomb muffle might work :shrug:
  12. t3t4_4g63 New Member
    Jul 2, 2007
    Message Count:
    94
    do you have a site where i can find it? any other suggestions?
  13. sleeper_inc New Member
    May 4, 2007
    Message Count:
    92
  14. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    As I assume you know, I sell complete exhaust kits too. Matter of fact, I'm the only one that does so.
    As stated on my site, the FMIC kit is a bolt on deal. No mods needed. Rotating the intake is for aesthetic reasons, not for performance.
  15. t3t4_4g63 New Member
    Jul 2, 2007
    Message Count:
    94
    THANKS A LOT STINGER!! TRUST ME, AS SOON AS I GET SOME MONEY UP, YOU'LL BE GETTIN A LOT OF IT!! THANKS MAN!!
  16. sleeper_inc New Member
    May 4, 2007
    Message Count:
    92
    Sweet Deal:nice:
    Look for me to buy stuff from you down the line:p
Share This Page
