high speed control
Discussion in '2.3L (N/A & Turbo)' started by rike, Feb 17, 2007.
  1. rike New Member
    Feb 17, 2007
    Message Count:
    I've got a 92 rag that wants tofloat at speeds over 85. I know lowering it is the surest way but I'd rather not if a front curtain or a stiffer sway bar will get it done.
  2. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    A larger front swaybar and a rear swaybar will help alot, as will wider/lower profile tires on larger wheels.
  3. bhuff30 Founding Member
    Dec 11, 2001
    Message Count:
    5,751
    78
    You may want to check the tie rod ends to make sure everything is in good working condition before modifying. Certainly, it will feel more unstable at speed with worn out tie rod ends, and those can go out frequently.
    Otherwise, as stinger said. Things to make the steering more precise, like a stiffer sway bar, stiffer springs or bigger wheels
Share This Page
