Hooking up Sub
Discussion in 'Mustang Sound & Shine All' started by cruisinV6, Feb 15, 2004.
  1. cruisinV6 New Member
    Mar 16, 2003
    Message Count:
    276
    I just bought my first aftermarket piece of audio equipment. It is a 10" Pioneer sub. I was wondering how i go about wiring this thing up. All of the factory speakers have wiring harnesses on them, so i cant plice them, or can i? Is there an extra spots to wire a sub on the factory amp? Any and all help is appreciated.
  2. Poopie D New Member
    Jan 4, 2004
    Message Count:
    70
  3. cruisinV6 New Member
    Mar 16, 2003
    Message Count:
    276
    I do not have a Mach 460 or 1000 system, so is the wiring similar to those system for the stock parts.
  4. cruisinV6 New Member
    Mar 16, 2003
    Message Count:
    276
    I am looking for step by step instructions on how to install an amp and sub to my 99 factory sound system, not the Mach system. Can anybody help me on this?
  5. chrisbudl1 New Member
    Dec 22, 2003
    Message Count:
    444
    I would imagine that unless you have pre outs of some kind, you are gonna have to splice into your rear speakers, somewhere. Then depending if your amp has high level inputs or not, you may or may not have to use a line in converter. If you follow the instructions over at mustangworld, that should give you some kind of idea, the only difference is where you get your input from. I just installed 2 12's on my mach system, it wasn't too bad. Try to find out how to remove your rear speakers, and try to splice into the wires. your signal to the amp might fade though, because as you increase the volume, your radio backs off some bass. The answers are out there, just search. If I can help anymore pm me. There are some good guys over at mustang exhaust also. Sometimes I get a faster answer there. Good luck
Share This Page
