I know that HP will vary from car to car....but does anyone know how much a 5 speed stock 5.0 fox RWHP should be?
Now that is a very intelligent piece of info to give.
My 84 carbed GT and 84.5 CFI GT were under 190 at the crank. Then a 86 would be different and again the aeros would be different.
Good point Smoke![]()
peace
Yeah, the CFI cars were 186 if I remeber right. 87-93 Foxes were all basically 225 but the way they were tested changed over the years. Also, the rule of thumb for power loss to the wheels is 15%. Some autos take more and some sticks may take a point or two less but 15% is widely accepted. So a Fox rated at 225 would make 190ish at the wheels just like 25th said![]()
Don't forget the 1993 mustang cobra:
Ford's Special Vehicle Team made it's debut with the 1993 Cobra Mustang. A total of 4,994 Cobras were produced for street use, while 107 Cobra "R" models were produced for showroom stock racing.
Ford's 5.0L engine used in the GT Mustang had many modifications done to it before being fit into the Cobras. Among these changes were higher-performance GT-40 cylinder heads, larger valves, and a stouter camshaft. The highly modified 5.0L V-8 was rated at 235 horsepower and 280ft/lbs. torque.
The same Borg-Warner T-5 transmission found on the GT was used for the Cobras, except it came with phosphate-coated gears as well as stronger bearings. Goodyear Eagle P245/45ZR17 tires were mounted on 17x7.5 inch aluminum wheels. Also on the Cobra were rear vented disc brakes instead of the standard drum brakes.
The Cobra had the same lower grille as the GT, but minus the side scoops. The front fascia contained a grille opening which carried a running horse emblem. The one-piece fascia in the rear had cutouts for the exhaust tips, as well as a rear spoiler. The only differences on the interior of the Cobra from the GT was a white instrument panel as well as "Cobra" embroidered floor mats.
The Cobra "R" model did not contain power windows, door locks, a stereo system, or air conditioning. There were also no fog lamps and the wheels of the "R" model were painted black. The suspension was also firmer.
