How do I remove my windshield wiper arms?
Discussion in 'Mustang II' started by 1badII, Jul 1, 2006.
  1. 1badII Member
    Aug 5, 2003
    Message Count:
    814
    The repair manual says to lift the arm away from the windshield and press the little spring clip, and the arm will lift off. I've pushed and pulled the clip every which way, and I still can't get the ****es off! What am I donig wrong? I'm about to take the dremel to it!
  2. mustangmods New Member
    Oct 25, 2005
    Message Count:
    49
    Ya, thats the way. The tab should pull out about 1/4 inch. But if they are anything like mine which had not been touched in 20 years, they aren't going to just fall off.Once you get the tab out just keep working the wiper back and forth and it will let go. Some WD40 will help.
  3. 1badII Member
    Aug 5, 2003
    Message Count:
    814
    I'm pushing the clip in, and the arm will move just a little bit up and down, like something is still holding it down.
  4. Power Surge Founding Member
    Jul 20, 2002
    Message Count:
    1,521
    You need to pull up on the arm so it's at a slight upward angle, and then you need to pull the tab on the side of the base OUTWARD. You might want to use a small flat blade screwdriver to pop the tab. Then the arm pops off.
  5. Kilgore Trout Fried or Broiled ?
    Mar 31, 2005
    Message Count:
    8,280
    76
    Look at the tab on the arm closely, figure it out :shrug:
  6. 1badII Member
    Aug 5, 2003
    Message Count:
    814
    I can't lift the arm up high enough to see underneath good enough to tell how it all works. There isn't a tab that pulls out from the side.
  7. 2muchtime Founding Member
    Jan 30, 2002
    Message Count:
    895
    it pulls out ... towards the blade itself... a sm. screwdriver works
    (not standard size) pry it away from the right side of the shaft..
Share This Page
