I’m building an, ideally, 400 hp 351 that will rev to 6000 rpm, designed for 99% street. Little to no actual racing, just spirited onramp sprints. AFR 185/Stealth/appropriate cam/yadda/etc. I want the engine to last a while. I also don’t want to waste money. I was planning on getting better than OE pushrods, lifters, bearings, etc… but there are several components, some of which I’m not sure what they do, that some use to help with this longevity. I’ve also heard most of them described as unnecessary, useless, or even counterproductive in some cases. So, could someone tell me if any of these components below would be worthless/damaging, unnecessary, or a very good idea with my setup?
1) Aftermarket, SFI approved harmonic balancer (I usually hear stockers are good to 6k… does that mean I’m golden or that I am pushing it?)
2) Windage tray (don’t know what this does)
3) Stud girdle
4) High volume water pump or water pumps with impellers (never heard anyone attest to these actually helping in keeping the engine cool)
5) High capacity oil pan (I would think this is unnecessary for my purposes)
6) High volume oil pump (heard that this can actually be harmful… which would be important because I believe I already have one)
7) High performance gaskets (I believe Fel-Pro has two lines, and I also think I heard someone say on here that the higher-end ones were actually worse…)
If these (or others that I don't know about... let me know, please! i want to do this right) a good idea, even if unnecessary, and won’t break the bank, I’ll probably just get it. But itd also be useful to know if they'd be completely worthless or if the parts could actually work against me. If they are, indeed worthile, if you could recommend a specific company/part # it’d be helpful. Also, if there are any compatibility issues with other engine parts… that’d be good to know too.
Don't hesitate to ask if you need more details on the engine setup or what I want to do with it, let me know. Thanks a lot!
3) Stud girdle
With good reason too.
