iac and gasket question
Discussion in '2.3L (N/A & Turbo)' started by glowstang93, Jan 18, 2009.
  1. glowstang93 Member
    Feb 9, 2003
    Message Count:
    822
    Illinois
    I have a new IAC to put on and it came with a new gasket. Do I need to change the gasket if the old one is still in good condition, not torn. And if so, is there any glue, oil or sealant that should be used between the throttle body or the iac body?
    Thanks in advance
  2. ethangsmith New Member
    Jan 29, 2007
    Message Count:
    227
    Manheim, PA
    I've reused my old gasket quite a few times. As long as there are no tears on it and it's not brittle, you can reuse it. I like to use a little bit of gasket adhesive or some vaseline though.
Share This Page
