Idle Help
Discussion in '94-95 5.0 Tuning' started by Guero, Apr 14, 2007.
  1. Guero Active Member
    Oct 12, 2005
    Message Count:
    2,195
    46
    So I kinda got my idle pretty good at a stand still, but if the car is rolling and speeds like 20MPH+ it idles like around 1500 rpms. Were do I go in Tweecer to fix this???? Thanks guys
  2. tjh566 New Member
    May 22, 2004
    Message Count:
    615
    Northern Va
    It suppose to do that, Theres a certain command in there that it wont allow a drop to idle unless your going like less than 5 mph. I dont think you can fix that. Mabye grady and come in here and confirm this.
  3. Guero Active Member
    Oct 12, 2005
    Message Count:
    2,195
    46
    Thats gay cuz its f'ing annoying
  4. tjh566 New Member
    May 22, 2004
    Message Count:
    615
    Northern Va
    just gear brake, sounds better anyways :nice:
  5. final5-0 Mustang Master
    Apr 7, 2003
    Message Count:
    6,808
    78
    DFW Texas
    I've found you can have that hanging idle if you got two things outta
    whack that kinda work together.
    The tb blade stop screw
    and
    The tb air bleed screw
    Basically ... you wanna have the stop screw just barely holding the blade
    open to keep it from sticking on the side of the tb bore.
    I have seen the bleed screw being out too much will also cause this issue
    These two next things can greatly help you obtain a stable idle ;)
    You also wanna up your tb airflow value scalar a bit
    and
    Your ISC Neutral Idle Airflow function values as well
    There are specific procedures for obtaining the best values for that
    scalar and those function points
    Look here in tech and tuning for info about the methods
    and
    I think I got some info on my site for the details as well
    however
    If you wanna shoot from the hip :D
    You could add about 10% to each function cell
    and
    About 70% to that scalar
    It should get you closer :shrug:
    Grady
  6. tjh566 New Member
    May 22, 2004
    Message Count:
    615
    Northern Va
    that will help it but ive read around and people said you cant get it to go completely away because of a function of the comp, ive tried to get mine to go away, now it only hangs at like 1100 or so.
  7. final5-0 Mustang Master
    Apr 7, 2003
    Message Count:
    6,808
    78
    DFW Texas
    I agree ... My findings as well :nice:
    I did not mean to imply you could make it go completely away.
    A certain amount of that is normal and intended by Ford.
    I should have made it clear my focus was on an excessive amount.
    Grady
  8. WhiteDevil New Member
    Feb 5, 2003
    Message Count:
    2,720
    San Diego
    Mine drops to around 1100 while im coasting until i am almost to a stop the it drops to my 800rpm idle. Seems pretty normal to me.
  9. m0l0 New Member
    Nov 21, 2005
    Message Count:
    178
    Yes Hanging idle is normal to some sort of grade, how ever there is a function called "ISC Dashpot Decay Rate" where you can adjust the dropping of rpms on neutral, i have not tried that function personally but a lot of peeps use it, you can give a try
Share This Page
