idle problem
Discussion in '94-04 V6 Mustang' started by henrie, Dec 9, 2003.
  1. henrie New Member
    Jun 23, 2003
    Message Count:
    18
    i just put a 2.5" offroad h-pipe and a spintech side exit system on my 95 coupe. the problem i have is the idle has dropped to about 500, and pulsates up to a 1000 and then back down again. does anyone know the cure to this problem. and my gas milage has dropped considerably is this a normal problem with the addition of the pipes.
  2. JDMsTangR New Member
    May 12, 2003
    Message Count:
    283
    the only problem that ive heard from having an off road h pipe is only having their check engine light come on.
  3. SpectorV Founding Member
    Sep 3, 2000
    Message Count:
    1,872
    check for exhaust leaks.... reset the ecu, doubt it will help... but you never konw, make sure the o2 sensors are all in also, even though they will trip a code, you can idle it up wiht the idle set screw on the throttle body also.
  4. henrie New Member
    Jun 23, 2003
    Message Count:
    18
    thank you. do you know if the gasmilage dropping is normal for this type of mod.
Share This Page
