Ignition question
darkhorse1
121
Indiana
OK this is prob a stupid question, but where is the Powertrain control module(PCM) located? I have to send my MSD out to be repaired so I figured that I would try the stock ignition, but I can't find any loose plugs or wires. Anyone have any idea if I can run the car like that. Thanks.
Well, I can answer one of your questions. The PCM is located behind the passenger side kick panel. It's kinda tricky to get it in and out of there but it's do-able. Plus there's a bolt, I think it's a 10mm, that secures the wiring plug to the PCM. The manual says to disconnect the battery before removing it in case of the airbag sensors being set off... not sure what the deal is with that, but better safe than sorry... those things are wickedly expensive.
