intake ?
Discussion in 'Mustang II' started by manny, Feb 7, 2004.
  1. manny Founding Member
    Dec 6, 2001
    Message Count:
    597
    i'm going to put an aftermarket manifold on the 302 and i've seen some with and some without the rear water cross over.the stock manifold does'nt have that cross over path.can i just block that passage or just leave it alone?is better for cooling? i'm looking at the rpm air gap manifold. any one out there use a manifold made by performance products?
  2. jeffnoel Founding Member
    Sep 1, 2002
    Message Count:
    1,681
    Yeah, I have the non air-gap model I forget what they call it. It's polished and seems to be well made (made in China). As for how it works I can't say much I've only put about 40 miles on it last year and now it's time to put the 2-bbl manifold back on for the biannual smog check.
  3. COBRA 7 Founding Member
    May 19, 2000
    Message Count:
    442
    18
    The rear water ports on the intake have to be blocked. If they are open, the cooling system won't circulate correctly.
  4. manny Founding Member
    Dec 6, 2001
    Message Count:
    597
    thanks cobra7, thats what i thought. :nice:
  5. 77sleeper GO BUCS!
    Oct 11, 1999
    Message Count:
    7,495
    is that why my stealth equipped car allways runs hot?
  6. Dano78 Founding Member
    Nov 1, 1999
    Message Count:
    2,662
    What?? I had a Stealth on my II (on the old 302 engine- 388hp) and it never ran over 190!
    And IIRC most your 60's ford intakes had rear water crossovers. (correct me if I'm wrong)
    Anyways... first I've ever heard that :shrug:
  7. 77sleeper GO BUCS!
    Oct 11, 1999
    Message Count:
    7,495
    :owned: :bang:
  8. myfirstii Founding Member
    Feb 28, 2002
    Message Count:
    401
    Are you serious! Ive had a rpm air gap on mine for about 2000 miles or so and im pretty sure i havnt had any problems with overheating due to the cross over. Anyone know if this is true that you have to block it??
    Pat
  9. 98CobraClone New Member
    Feb 28, 2003
    Message Count:
    636
    I've run the Edelbrock Performer 289 intake on mine since I first bought it.....I haven't looked at the water passages to see if they are or aren't on there, but I never had any problems with overheating. That included 30 miles roundtrip daily for 2 years and then about 200 miles back and forth to school when I was in college.
    I'd go check it out, but the intake's bolting onto the engine
  10. dmoody Founding Member
    Nov 4, 2002
    Message Count:
    798
    Don't quote me on this one, but if I remember correctly there are two of the four possible water passages open on the Edelbrock Performer intake. They are diagonally across from one another so I can only assume that water flows through the intake from one into the other.
    d
  11. 75stang302 Founding Member
    Mar 31, 2002
    Message Count:
    1,036
    the water comes up from the block into the heads.then it flows from the rear of the heads to the front where it goes int the intake and into the water outlet
Share This Page
