Interested in a PMS
Discussion in '94-95 5.0 Tuning' started by Green Machine, Apr 28, 2006.
  1. Green Machine Founding Member
    Sep 22, 2001
    Message Count:
    442
    From reading the sticky's it looks like the PMS is a good thing to have for our
    94-95 PCM's, especially for those that are Tweecer challenged.
    I was considering have a chip burned for my current mod's, but I want to upgrade to a CHP 347ci long block, which will definitly need a good tune to make it run good.
    A few questions to run by you.
    1. Can I adjust the A/F settings on the fly ? I put down 271/305 with the A/F = 13.8 I think there are some more hp to be found in my combo till I can get the 347 installed.
    2. Can I adjust the timing ? Currently have 12*, again I think there more hp to be found.
    3. I have some surging probably due to the C&L MAF, but could I adjust that up to say 800-900 rpms ?
    4. Is Anderson Ford the best place to purchase etc?
    5. Is the PMS easy to use ?
    Thanks, Dewman:nice:
  2. Redsnk95 Founding Member
    Feb 4, 2002
    Message Count:
    2,246
    Yes to all your questions. You can change timing and fuel as you are driving or have someone drive while you make changes. It is as simple at +/- fuel percentage or timing degrees. Fixing the Idle Surge shouldn't be a problem with the PMS. I would go through AFM if possible, but there are plenty of dealers out there. I have some start-up tunes on my site as well.
    Troy
  3. Yellow94 New Member
    Apr 10, 2006
    Message Count:
    20
    The AFM PMS is very good for you current configuration and will work just as good with you new one. As far as your surging, I would check your idle adjustment and your TPS before you start changing anything on you PMS.
  4. nmcgrawj Advanced Member
    Sep 28, 2003
    Message Count:
    3,671
    66
    Easy is an understatement for how easy the PMS is :nice:
  5. milehighstang New Member
    Mar 31, 2005
    Message Count:
    62
    Greemachine, i def am not tryin to steal ur thread, but i two am interested in the pms, but i heard that u cant make adjustments lower than 2000 rpms and up. And i would def like to make some adjustments to the idle. Can the PMS modify our cars idling characteristics?
  6. nmcgrawj Advanced Member
    Sep 28, 2003
    Message Count:
    3,671
    66
    Yes. Just go to andersonfordmotorsport.com and look at the manual. The PMS can tune the car just as well as a tweecer or any other form. :nice:
Share This Page
