Jet Performance Chip
Discussion in '2005 - 2009 Specific Tech' started by Redfire 05, Apr 7, 2005.
  1. subzero05 New Member
    Dec 21, 2004
    Message Count:
    191
    My mileage is about 22-23 on the hwy and 15-17 in town..My computer average is about 21 overall so I am happy with that.This has pretty much remained the same since I installed the Jet module.Not a big performance enhancer, but definately better throttle response
  2. topless beach New Member
    Mar 31, 2005
    Message Count:
    48
    I used to drive an Audi A-6 2.7T, and I remember some owners who chipped their cars would buy a separate "computer module"; chip one of them, and put the unchipped module back in every time they took it in for warranty work.
    Is that viable in the stang?
  3. subzero05 New Member
    Dec 21, 2004
    Message Count:
    191
    yes it is viable with the Jet module to take out and re-install as needed
  4. Redfire 05 New Member
    Apr 7, 2005
    Message Count:
    242
    Lubbock, TX
    I'm not sure exactly what it would show. For one I don't know what all the computer records other than rpm. The chip modifies the signal coming from the sensors to your car so yes I suppose the sensor readings would be different than what Ford would expect if it records them all. But I think it's unlikely that I will blow my engine. I don't drag race. This is my daily driver, and other than a few spirited slides around corners it doesn't see much abuse. I want the chip for one reason, to get rid of the lag in throttle response. This chip will do it for half the price of a tune that likely will cause warranty problems. I know a custom tune would be better if I wanted to increase my horespower, but at this point I don't. Honestly, I will probably get a custom tune when my warranty runs out. However, for the time being this will do the job. All I want is the throttle to open when I push the gas pedal. If someone came out with a plug in device for $50 that corrected the throttle response, I would buy it instead.
    Is it worth it? I am a convert from the Turbo Buick crowd. Chips for those cars were $25 - $75 for really good ones (please don't lecture me on how different things are between the two ecu's I am well aware of the differences). So really all of this stuff is overpriced as far as I am concerned. So if you don't believe the chip is worth the $200, then don't buy one. But I will because it is exactly what I want at the lowest price.
  5. NY05GT4ME New Member
    Apr 2, 2005
    Message Count:
    38
    Upstate NY
    I understand that because of the sensitivity of the air/fuel mixture in the 05's they require a re-tune for any modifications. I'm planning on installing a CAI on mine. Will the JET module take care of this for me? I'd rather not spend 400$ on a predator and risk losing my warantee. Thanks. :)
  6. subzero05 New Member
    Dec 21, 2004
    Message Count:
    191
    if you just install the jet module you will not need a tune because it is calibrated with the correct A/f in mind right out of the box.If you add a CAI though you will still need a tune
  7. NY05GT4ME New Member
    Apr 2, 2005
    Message Count:
    38
    Upstate NY
    I decided to wait on the CAI for now, just going with the jet chip and loudmouth axleback for now.......they'll be here in a couple days...cant wait... :D
  8. subzero05 New Member
    Dec 21, 2004
    Message Count:
    191
    I only put in the JET module as a temporary thing until the shaker system comes out .I am planning on getting that unit which will require a tune anyways so then the JET module will be for sale.I already have the predator sitting in wait for the shaker to get installed but the JET did give the car a little more spunk which was all I was looking for in the interim anyways.
  9. NY05GT4ME New Member
    Apr 2, 2005
    Message Count:
    38
    Upstate NY
    whats the shaker system? :shrug:
  10. subzero05 New Member
    Dec 21, 2004
    Message Count:
    191
  11. 05GT_EnFuego New Member
    Apr 7, 2005
    Message Count:
    san jose, ca
    ...hmm im not to clear on the jetchip,,, once its installed do we need to have it dyno'd and recalibrated or is it a chip that needs no modification once installed// i too just want to get rid of the lag on the car until warranty runs out then ill look into other things.. really want to get something i dont have to take to have dyno'd and tuned since i dont know of any good shops that are trustworthy wit my stang... thanksss.
  12. subzero05 New Member
    Dec 21, 2004
    Message Count:
    191
    No tune required with the Jet module..Just plug it in and go.
  13. 05GT_EnFuego New Member
    Apr 7, 2005
    Message Count:
    san jose, ca
    hmm that might be thing for me then,,thanks :)
  14. nik73 New Member
    Nov 21, 2004
    Message Count:
    Any new info or experiences with this route?
  15. NY05GT4ME New Member
    Apr 2, 2005
    Message Count:
    38
    Upstate NY
    I've been running the jet module for about a month now and really all it seemed to do was noticeably improve the drive by wire lag when you floor it at speed, and there is a slightly better midrange-topend power....
    Its decent if you dont want to do anything else to the car and risk voiding the warrantee but if i could have the 200$ back and put it toward the diablo/CAI when I was ready, i'd probably do that...........
  16. Szlachcic New Member
    Mar 31, 2005
    Message Count:
    174
    Raleigh, NC
    I was under the impression that if you tune using something such as the Predator that you are able to restore the factory settings. Would the dealership still be able to see that you tampered with the computer or does this fix the problem. I am just curious since I was thinking about purchasing a Pred and a CAI, but if this will cause me more problems than it is worth then I might rethink what I am doing.
  17. kellera6 New Member
    Oct 9, 2004
    Message Count:
    36
    I installed the Jet chip on my auto GT and it has improved the throttle lag and the tranny does seem to shift faster. Overall the car runs a lot smoother. Does it seem like it has more power? I can't answer that question because I was already scared with the power it had :)
Share This Page
