Knock when accelerating, especially up hills.
Discussion in '94-04 V6 Mustang' started by gmssage, Mar 9, 2004.
  1. gmssage New Member
    Mar 9, 2004
    Message Count:
    My 1997 Mustang has a noticeable, but not overly loud knock when accelerating, especially when going up hills. It is not quite so loud when on a flat road.
    I just changed the spark plugs, thinking that it would be due to spark knock, but I didn't change the wires. After having the plug changed, the sound still continued.
    I also tried running a higher octane gas (went from 87 to 93), but that made no change.
    Any help in diagnosing and fixing this would be much appreciated.
  2. xneox New Member
    Jan 14, 2004
    Message Count:
    36
    This is one of those things that's nearly impossible to diagnose thru the 'net. Could be anything from an alternator bearing to a main bearing.
    How many miles?
    Oil change intervals?
    Spark knock & bottom-end knock sound nothing alike, so if you can't distinguish between the two maybe you have a bud that's into cars & will go for a ride w/you to help nail this one down.....?
  3. Jamez Founding Member
    Mar 2, 2000
    Message Count:
    2,610
    Mine sounded like it was knocking when one of the primary tubes cracked.
  4. gmssage New Member
    Mar 9, 2004
    Message Count:
    63,500 miles, with oil changes every 3,000 miles using Pennzoil 5W-30.
    It's more of a higher pitched, extremely rapid knocking sound, and it doesn't happen at all while in park/neutral.
  5. Mach428 New Member
    Dec 8, 2003
    Message Count:
    326
    Answer these questions for me, Is it one loud knock and do you have an auto?
  6. 98CobraClone New Member
    Feb 28, 2003
    Message Count:
    636
    extremely rapid..........valve lash??????
  7. gmssage New Member
    Mar 9, 2004
    Message Count:
    Yes, it's an automatic.
    No, it's not one loud knock. It sounds like a lot of semi-quiet little knocks, rather rapid, probably about 7-10 little knocks a second while accelerating.
  8. xneox New Member
    Jan 14, 2004
    Message Count:
    36
    Sounds like top-end from what he's describing.....but I've heard belt/chain tensioners & accessory bearings make that kind of noise too....
  9. Mach428 New Member
    Dec 8, 2003
    Message Count:
    326
    I know on my v6, after 50,000 miles, the trans like to make all funny little knocks, every think you might be hearing something from the trans downshifting?
  10. gmssage New Member
    Mar 9, 2004
    Message Count:
    If it was the transmission, wouldn't it just be while it was shifting then, instead of constant? :shrug:
  11. Mach428 New Member
    Dec 8, 2003
    Message Count:
    326
    allot of the v6 trans like to do funny crap, i'm not sure
Share This Page
