LoadX, sea level load, ect...
Discussion in '94-95 5.0 Tuning' started by blksn955.o, Jul 10, 2009.
  1. blksn955.o Founding Member
    Mar 15, 2002
    Message Count:
    3,266
    66
    st.louis mo 314
    Lets talk about load...
    Our cars are Load based and that load is noted as LOADX and figured from the MAF. This load gets all the tables to use the correct cells and what have you. That is the basic run down.
    Other than old topics I recall from the eectuning forum going back 4-5yrs+ I just dont recall any real topic on our sea level load and the need/ways to change this.
    N/A would need different load figures than boosted or n2o apps I would figure?
    How do you know your sea level load is set correct? I have always wondered this question? Good drivability is one thing but what about the WOT area?
    The reason for this post for myself is the WOT area, I have noticed that my A/F WOT is solid in the correct load but that load at WOT seems to change and then my A/F seems to change (correctly based on the load amount). Its not a HUGE difference but its has me wondering this could leave power on the table as it is regular and seems to change more with the gear I am in. I have done nothing with my load settings in the eec outside of setting my CID scaler to the correct size of my engine if that even does anything.
  2. blksn955.o Founding Member
    Mar 15, 2002
    Message Count:
    3,266
    66
    st.louis mo 314
    anyone know any specific details on making sure your sea level load is correct?
    That and how much shifting from gear to gear (1st on threw 4th) changes that load reading?
  3. pirotec354 New Member
    Aug 29, 2008
    Message Count:
    129
    Grand Rapids, Michigan
    What do you have your load scaling switch set to?
  4. blksn955.o Founding Member
    Mar 15, 2002
    Message Count:
    3,266
    66
    st.louis mo 314
    Stock j4j1 setting, the only thing I have done is calc. the actuall C.I.D. of the motor (306.133). I have done nothing with the load switch or the sea level load table.
  5. Stanger007 Founding Member
    Sep 26, 2001
    Message Count:
    2,029
    Baton Rouge, LA
    I set load scaling to 1 on the blower cars (and N/A) I tune, making loadx=load.
    This simplifies a good many things.
    For your load being "off", watch your MAF voltage, is it getting as high in each gear?
    Wes
  6. blksn955.o Founding Member
    Mar 15, 2002
    Message Count:
    3,266
    66
    st.louis mo 314
    I will have to check the MAF voltage...
    I thought the j4j1 base program was already loadx=load? If it is not I will change it for the N/A side of things. What about a n2o tune?
    IIRC the loadx=load thing is basically just running off the MAF at that point correct?
  7. Stanger007 Founding Member
    Sep 26, 2001
    Message Count:
    2,029
    Baton Rouge, LA
    It'll just change it so that every table that uses "Load" as an axis will use the same # you see in the datalogs. You do not have to remember which uses load % and which use load. Makes it easier tuning.
    Since Load is roughly the VE of your engine it should line up to the airflow mass entering in the engine. See how your MAFV corresponds to LOAD.
    If you find that Load goes over 100% on a N/A combo you should check your injector sizing and MAF curve.
    When spraying nitrous you should see slightly less load - you are displacing air with the nitrous/fuel you are spraying in the intake.
    Wes
  8. blksn955.o Founding Member
    Mar 15, 2002
    Message Count:
    3,266
    66
    st.louis mo 314
    That might help stabilize things a bit then.
    Would you suggest keeping the load at 1 for a n2o tune or leaving the load switch at the same setting in the stock j4j1 programming?
    oh, thanks for the help Wes
  9. Stanger007 Founding Member
    Sep 26, 2001
    Message Count:
    2,029
    Baton Rouge, LA
    I'd leave it at 1 and tune from there.
    No problem on the help -- if you ever want me to look over your datalogs/tune let me know and I'll be happy to help.
    Wes
Share This Page
