lowering
Discussion in 'Mustang II' started by dmann253, Sep 11, 2006.
  1. dmann253 New Member
    Jul 18, 2004
    Message Count:
    37
    I want to lower my mustang in the front about 2 inches i bought some lowereing spindles but they caused my rims to not work so does anyone know of lowering parts that work with the original 13" rims?
  2. Addicted_2_II New Member
    Dec 29, 2003
    Message Count:
    187
    My front-end already sets too low and I scrape at just about every speed bump! Have you moved your Radiator up or something?
    Sorry I guess I am no help on this one.
    Chad
  3. itsaMustangtoo New Member
    Apr 2, 2005
    Message Count:
    292
    You could buy fox body springs like I did. ( 86 GT v-8 ) Then proceed to cut, install , remove ,cut ,reinstall. The springs are fairly inexpensive from autozone or advance. 1 wrap, or coil equals about 1 inch. But a word of caution, after the first wrap comes off, reduce cutting to half a coil and then a quarter till you get it where you like it. These springs have a better rate than the mustangII springs, they do not bounce like the ii's and will over all give a better ride.
  4. jeffnoel Founding Member
    Sep 1, 2002
    Message Count:
    1,681
    If your buying new spring to cut, before you get to far install them and let them settle for a couple weeks otherwise you may end up lower than you want.
Share This Page
