Mach 460 Amp Location?
Discussion in 'Mustang Sound & Shine All' started by ufomoto, May 7, 2004.
  1. ufomoto New Member
    Apr 13, 2004
    Message Count:
    Can anyone tell me where the tweeter/midrange amp is located on a 2004 GT. Its suppossed to be under the radio in the center console, but I can't find it. Did the location change in 04? Thanks for your help.
  2. saxman9801 New Member
    Jan 27, 2003
    Message Count:
    241
    If i remember correctlty on the newer mach 460's the tweeters are powered off the headunit and then you got two amps underneath the rear deck if it is a coupe or underneath the vert well if it is a vert.
  3. Mossberg Active Member
    Jul 22, 2003
    Message Count:
    1,212
    36
    yep, it's in the radio on newer stangs.
  4. 2002GreyGT New Member
    Jun 10, 2003
    Message Count:
    479
    I think it may be in that big black POS that hangs from the rear deck. Dont remeber if there were 2 or just 1 amp in mine when I took it out...really did not care
    ~K
  5. active SVT New Member
    May 8, 2004
    Message Count:
    I've got an o3 convert and there's 2 under the bag. Not sure why there's 2 though. Anyone know?
  6. saxman9801 New Member
    Jan 27, 2003
    Message Count:
    241
    Each amp does two speakers one front and one rear, then your headuint powers the 4 tweets. Dan
  7. active SVT New Member
    May 8, 2004
    Message Count:
    saxman,
    I was just out farting around with those amps. Any idea why when I unplug the one on the driver's side no sound change happens?
  8. saxman9801 New Member
    Jan 27, 2003
    Message Count:
    241
    There will still be two speakers workin plus all the tweets when you unplug one amp, could be you just don't notice it or perhaps a speaker is bad and is not playing all the time anyways one amp does each side if i remember correctly, unplug the amp and then listen carefully to each speaker i would bet you just don't notice when you unplug it. Dan
  9. active SVT New Member
    May 8, 2004
    Message Count:
    saxman,
    you are right. Man, the subs are so subdued. I don't know why it needs four of them. Seems like just 2 in the back would sound better. Then replace the 2 up front with a good 3-way.
Share This Page
