mach 460 removal
Discussion in 'Mustang Sound & Shine All' started by Q's Stang, Oct 15, 2004.
  1. Q's Stang New Member
    Jun 29, 2004
    Message Count:
    317
    i was wanting to remove my mach 460 system and upgrade to better speakers...the front speakers shouldnt be that hard to swap, but today i was looking at the rear 6x8's and the amp rack and i wasnt quite sure how to uninstall it. if anybody could help me out w/ how to remove the amp rack, im sure the speakers themselves wont be hard at all to remove. and also, how much do used mach 460 system sell for?
  2. nmcgrawj Advanced Member
    Sep 28, 2003
    Message Count:
    3,671
    66
    Lay on your back in the trunk and look for the bolts holding the amp rack up. For the rear speakers you gotta take that back dash out under the window, it just pops out and then you can take the speakers out.
    Have fun! I rewired the whole car when i dumped my mach system....
  3. GI Joe 97/02 Founding Member
    Jul 12, 2002
    Message Count:
    1,820
    I pulled the 4 bolts and it still dont come offf...just wiggles...what do I have to do get rough with it..lol?
    I want to remove the radio too and put another in but keep the 4 front speakers...how do I do that..the new radio will be powered...Is there a harness?
    Thanks
    Regards
    GI joe
  4. nmcgrawj Advanced Member
    Sep 28, 2003
    Message Count:
    3,671
    66
    you gotta re-wire the whole system starting from the new radio. Run new wires from each speaker output of the radio to each speaker.....the car harness wont work since it wires into the amps that u are removing....
    i dont remember how many bolts hold the rack up. Is there one in the middle? Go through and double check and make sure you get them all, once all the bolts are out, mind dropped on my chest lol :rolleyes: Its hard to see up in the holes so get a flash light to help.
    Good luck!
  5. jaredg16 New Member
    Oct 31, 2008
    Message Count:
    18
    Could you just replace/upgrade the rear speakers if you plan to keep the two amps already installed in the Mach 460 system? I have already installed a new receiver (Pioneer FH-P8000BT) with the harnesses and it works wonderfully. If I decide to upgrade to some different speakers in the rear (same side... would just be swapping the stock out for some new ones), couldn't I just pull out the two original ones that came in the Mach 460 system and connect the two new ones?
  6. 2BADSTANGS New Member
    Jun 19, 2008
    Message Count:
    398
    The problem is, if you keep the amps, they are internally crossed over. If you put aftermarket components in, they have their own crossover that needs full range input and hooking them directly to the factory wiring without their cross over could damage them.
  7. Steel68 New Member
    Nov 6, 2008
    Message Count:
    Would you be interested in selling the wiring harness? I've got a 03 that i'm putting together (salvage car) and i'm missing the harness for the amps/speakers.
  8. jaredg16 New Member
    Oct 31, 2008
    Message Count:
    18
    That would make sense. So if I would get new rear speakers it'd be best to remove the factory Mach amps as well. Would I have to rewire from the receiver back to the rear speaker area as well?
    Thanks for the input 2BADSTANGS!
  9. 96_Drift_Stang New Member
    Nov 9, 2008
    Message Count:
    is there a way to use the stock amps? i want to use them for the speakers and have an aftermarket amp just for my sub
  10. 2BADSTANGS New Member
    Jun 19, 2008
    Message Count:
    398
    I used the factory's wiring, but rewired it to bypass the amps and feed my aftermarket crossovers/ speakers. Using the factory wiring is nice, 'cause it's allready run, however it can be a bit confusing if you are unfromilliar with how the system was wired from the factory.
  11. MustangLife New Member
    Jan 6, 2003
    Message Count:
    1,291
    Allright, when you say re-wire the whole car after removing the rear deck and two factory amps. With the new speakers. Giving theres already a aftermarket head unit hooked up. Can you just run the new speaker wire from thje head unit to the new speakers ?
Share This Page
