Magnaflow
Discussion in 'SVT Forum' started by hvcobra99, Dec 7, 2007.
  1. hvcobra99 New Member
    Jul 21, 2006
    Message Count:
    82
    Plymouth MI.
    I just installed magnaflow xpipe and cat back and love the sound, Any one with ? about exhaust I would go magnaflow in my opinion
    they do not make headers so Im deciding on either mac or headmen midlenths would love to hear your opinion or should I stay with stock
  2. COBRA90GT Moderator
    Sep 22, 2001
    Message Count:
    6,836
    86
    HOCKEYTOWN ® , MI
  3. Uncle Meat Banned
    Jun 13, 2002
    Message Count:
    3,869
    Prattville, Alabama
    I concur, no MAC headers. You've got a high quality mid pipe and cat back on the car now, don't skimp out on the headers.
    U.M.
  4. hvcobra99 New Member
    Jul 21, 2006
    Message Count:
    82
    Plymouth MI.
    thanks guys
    Hey uncle meat could you give a step by step guide on how to remove the drivers side valve cover on my 99 cobra. Also one of my spark plugs had some rust on it should I be worried what?
    thanks once again for the advice
    also what headers should I go for Long tube or mid and what company
  5. Uncle Meat Banned
    Jun 13, 2002
    Message Count:
    3,869
    Prattville, Alabama
    Right off the top of my head I think it would require you to disconnect and remove the intake pipe from the throttle body. Then remove the two bolts holding the coil cover onto the valve cover. Once the coil cover is removed you can then take all the COP's off and remove the spark plugs. From there the removal of the remaining valve cover bolts should be all that's left I would think? Don't forget to replace the o-rings and gasket when you put it back on.
    As for the rusty plug I had that happen to me too last time I swapped mine. Somehow water had got down inside the #4 spark plug well which caused the plug to rust. Probably from me washing my engine and then not running it afterwards long enough to evaporate the water which worked it's way into the rear spark plug well...
    As for headers... whether you go with LT's or mids you'll need a mid-pipe too. There are some drawbacks to long tubes, especially if the car is lowered or if you plan on lowering it in the future. Do a few searches in here and the 4.6 forums and see what the other guys are recommending. I went with JBA shortys myself because it was part of the stipulation with my service department for keeping my warranty intact.
    U.M>
  6. Uncle Meat Banned
    Jun 13, 2002
    Message Count:
    3,869
    Prattville, Alabama
    My bad. I just went back and re-read your question and you were asking about the driver's side valve cover... That one often times requires you to unbolt the brake booster/master cylinder from the firewall so you can obtain enough clearance to get the valve cover off. I have read where some guys have manged to work it free without resorting to this though...
    U.M.
  7. hvcobra99 New Member
    Jul 21, 2006
    Message Count:
    82
    Plymouth MI.
    Thanks Mr uncle Meat
    Thanks alot for your help and happy holidays !
  8. hvcobra99 New Member
    Jul 21, 2006
    Message Count:
    82
    Plymouth MI.
    Uncle Meat is the bomb
    Thanks Uncle Meat for your wise advice. I got that drivers side valve cover in 1 1/2 first timer here. I managed to wiggle it out sometimes if you just take it slow and look before you leap you can accomplish alot. Thanks once more for the help.
  9. Gearbanger 101 That's my secret, Captain. I'm always angry!!!
    Aug 11, 2002
    Message Count:
    11,306
    52
    98
    Ontario, Canada
    How do you guys feel about BBK's for the 4V? They're certainly priced well. :shrug:
Share This Page
