Malfunctioning Speedometer
Discussion in 'SVT Forum' started by WarEagleCobra, Jul 24, 2004.
  1. WarEagleCobra New Member
    Jun 25, 2004
    Message Count:
    Auburn, AL
    Sometimes when I start my car, my speedometer doesn't work. Eveything else seems fine, except speedo and odometer. If I restart the car it corrects the problem. Also, if I'm driving and the speedometer isn't working and I brake hard to a stop the car stalls. This problem seems to be heat related as it occurs during the day when it has been sitting in the sun. It's a 99 Cobra. If anyone has an idea, I would appreciate the help.
  2. 54life New Member
    Jul 25, 2003
    Message Count:
    432
    Cali currently at Ft. Rucker AL
    try unplugging the whole speedo harness and letting it set for a couple of minutes and then plug it in and let it run through it's self configure mode and see if it helps....by chance do you have aftermarket gauge faces in it???
  3. atvcrazy New Member
    Jun 8, 2004
    Message Count:
    83
    Eastman GA
    I think if you unhook your battery your computer will reset
  4. WarEagleCobra New Member
    Jun 25, 2004
    Message Count:
    Auburn, AL
    No after market gauges. 100% Stock. How do I go about unpluggin the harness (Where is it located). Don't know a whole lot about cars, and brand new to mustangs. Thanks.
  5. 54life New Member
    Jul 25, 2003
    Message Count:
    432
    take the two screws on the top portion of your bezel out and pull that out. Next there will be four of those star screws (anti theft I forget there actual name) take them out and ease your gauge cluster out. It will barely pull out so next you have to disconnect the two groups of wires in the back of it by pulling up on the big tabs....you might have to get a small screwdriver and pry it the first couple of times. then you can take your gauge cluster out....I suggest cleaning it while you have it out. See if you can find a website that details a white gauge face install because it is the same premise and will probably have pictures. Ohhh yeah the hardest part is the first step actually before taking the two screws off you have to get your headlight knob off....you do this by pulling it out and rotating it until you see a recessed area with metal in the middle....take a screwdriver and press down on this metal and simultaneously pull it off and thats it.
Share This Page
