Manual Fan Switch
Discussion in '2.3L (N/A & Turbo)' started by Crovax, Oct 9, 2004.
  1. Crovax Type O Danzigative the Dark
    Sep 4, 2000
    Message Count:
    5,460
    88
    Which wire do you use, the power or the ground for the switch?
  2. Red_LX Doubt I could be of much help, unless you need por
    Aug 21, 1998
    Message Count:
    10,471
    78
    Doesn't matter, either way you're completing the circuit when you flip the switch.
  3. rgosulliv Founding Member
    Aug 10, 2001
    Message Count:
    434
    my fan was tempromental (worked some times and not other times) so what i did was
    splice a wire right into the hot side of the fan wiring and wire that to a switch and a LED.
    So that way it would tell me when it was on by lighting up the LED or I could manually force it
    to be on by throwing the swicth.
    The ground side is connected to a constant ground.
    The hot side is the trigger side (switch side).
    but like he said above it doesnt matter as long as you got hot and ground when you flip the switch.
  4. Crovax Type O Danzigative the Dark
    Sep 4, 2000
    Message Count:
    5,460
    88
    I had the power side switched and the fuse melted to the the fuse holder and popped last night after 3 years. i don't want to her to go up in flames.
Share This Page
