many problems
Discussion in '2.3L (N/A & Turbo)' started by sleeper_inc, Jul 1, 2007.
  1. sleeper_inc New Member
    May 4, 2007
    Message Count:
    92
    Regina Beach Sask. Canada
    I hit a junk yard up today and got a few goodies to tied me other for 2 weeks. I got 9x6 (or was it 10x6?) sony xplode speakers for the back of my car and they sound so much better than the stock ford speakers. I also got a TPS, and IAC from a 1990 Mustang coupe and a few underdash sensors also.
    So onto the problem.
    I need to know that sensor under the dash is for the (radiator) fan.
    And my idle is still high. although it does eventually go down to 900 - 1500 RPM (verys) so what else could be the problem? I know the TPS on the 90 mostang is different (or at least the TB is) so what could cause my ****ed up idle still?
    This is making me very pissed and I just want to rip that ****ing engine out and put a 350 chevy in there because it seem's so much easier
  2. sleeper_inc New Member
    May 4, 2007
    Message Count:
    92
    Anyone? I really need this fixed as I'm running out of time and I really don't have money to keep dragging this on
  3. sleeper_inc New Member
    May 4, 2007
    Message Count:
    92
  4. cjones Founding Member
    Jul 20, 2002
    Message Count:
    1,557
    36
    Avondale, AZ
    for the idle problem - check the IAC
    the temp sensor for the cooling fan is on the intake manifold(LH middle)?? what sensor are you talking about??
  5. sleeper_inc New Member
    May 4, 2007
    Message Count:
    92
    Its not the IAC, might be the TPS (idles 1500 with the IAC unplugged)
  6. kevinspann New Member
    Feb 25, 2006
    Message Count:
    93
    Richmond, VA
    With the IAC unplugged it should be idling at 750 RPM. Check the TPS voltage. Reset it or replace it and reset the TPS voltage to ~.94-.98. If that doesnt solve it, make sure that the throttle plate is closing all the way.
    http://www.muscularmustangs.com/tps.php
  7. sleeper_inc New Member
    May 4, 2007
    Message Count:
    92
    I'll pick up another TPS and test that out, if that doesn't work then I'll have to think of an engine swap soon
Share This Page
