mass air conversion?
Discussion in '2.3L (N/A & Turbo)' started by manny, Sep 10, 2005.
  1. manny Founding Member
    Dec 6, 2001
    Message Count:
    602
    TAMPA FL
    do you think it's possible to take a 5.0 mass air conversion kit and use it on a 2.3L speed density motor? reason for asking is that right now i'm running the 19lb injectors on the car and i'm looking for some more power with the mods that are on the motor. or would it be better to just get the ford motorsport part that can adjust the air/fuel mixture and extend the rev limiter? i car i used in scca racing.
  2. Mr. Merk New Member
    Aug 5, 2005
    Message Count:
    72
    NW Arkansas
    i just converted my 2.3T to a 70mm last night, right now i'm using a 93 cobra curve but i'll be changing that tonight i hope, its running good tho
    i dunno about your ECU how that would work, those kits come with an ECU, i chipped mine but i dont think i could make a file for yours
  3. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    Why not just get a used 91-93 mass air setup to throw on there?
  4. RustBucket New Member
    Jun 8, 2003
    Message Count:
    585
    Buford, GA
    There'd still be some ECU issues to work out if he went with the factory 2.3 MAF right? The ECU used for the MAF cars was also set up for dual plugs and no distributor so swapping ECUs wouldn't make it plug and play either.
    In all honesty, after you get done gathering parts, and buying an EEC tuner, would the benefits of swapping from SD to MAF be worth the investment?
    I'm not knocking the idea, just trying to sort through the facts and learn a little something along with y'all.
  5. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    Honestly, his best option may be to get a Megasquirt setup...or go to a turbo ecu and do the mass-air conversion with a J3 chip...and a custom tune.
  6. manny Founding Member
    Dec 6, 2001
    Message Count:
    602
    TAMPA FL
    the reason i'm asking is because my son and i will be doing the mass air upgrade on his 88 mustang gt. besides the mass air meter and tubes it's just about 6 wires and the new ecu. would an ecu from the 5.0 with mass air in it work on a 2.3 L? i am running the 19lb injectors allready. i plan on comparing the pin out of the 2.3 with the pin out of the mass air ecu 5.0 unit. hey stinger do you any knowledge of the megsquirt system? i do know that FMS does have a box that connects to the ecu and you can adjust the air/fuel mixture and extend your rev limiter, thats what i'd really like to do but the box is very pricey. the car in question is used only in scca road course racing. i really dont want to switch to a carb.stinger, very very nice site, you got me wanting to build a turbo 2.3 for just fooling around town.
  7. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    I haven't messed with megasquirt but I know some people that have.
    I really like the turbo ecu/J3 option the more I think about it...you can literally change EVERYTHING with that setup...pretty straight forward too.
    I doubt the 5.0 stuff will work right...it would be calculating the fuel for an engine twice the size of yours...
    Thanks, I think you need a turbo one too ;)
  8. manny Founding Member
    Dec 6, 2001
    Message Count:
    602
    TAMPA FL
    do you mean use the ecu from a turbo t/bird or svo? and the j3 chip? i'm lost about the j3 chip. where can one be had? and if i use the ecu from a tbird would i also use the mass air meter from the same car?
  9. manny Founding Member
    Dec 6, 2001
    Message Count:
    602
    TAMPA FL
    sorry about this but where can some one purchase the megasquirt system?
    thanks
  10. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    Yes, I'd look into a P series turbo ecu (early svo is the cheapest) and use a J3 chip. For simplicity, think of the J3 as the same thing as an EEC-Tuner...it does all of the exact same stuff, only it's 70 bux instead of 400. The turbo cars didn't use a mass air, they used a vane air meter (vam), only reason to snag it as well is so you can verify that the ecu swap works before moving on the the mass air swap.
    I plugged "buy megasquirt" into google and got this page: http://www.bgsoflex.com/mspo1.html That should show you a list of distributors for megasquirt.
  11. manny Founding Member
    Dec 6, 2001
    Message Count:
    602
    TAMPA FL
    thanks stinger, I'll be checking out the megasquirt system for my car. :nice:
  12. 88stangmangt New Member
    Nov 25, 2003
    Message Count:
    2,347
    Stafford,VA
    i have a motor/ecu out of a 88 TC and i hate the look of that VAM box hanging there.....so all i would have to do is buy the j3 chip??? and pick a maf out???
  13. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    Not exactly...in simplified terms that's all you do though...don't go into it planning on not doing some work...you best find someone with a wideband 02 sensor for tuning as well...
  14. 67efivert New Member
    Jan 27, 2003
    Message Count:
    348
    lincolnton nc
    stinger or anyone else for that matter that has done this can u be a little more spefic bout what all needs to be done to convert to mass air from vane air I will be using an la3 comp on this project or a p series if it would be batter( cant rember which one) thanks:)
  15. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
  16. Mr. Merk New Member
    Aug 5, 2005
    Message Count:
    72
    NW Arkansas
    unless you have access to a datalogging wideband with a rpm cable (for the MAF voltage)
    dont bother....i'm going through hell with this thing
Share This Page
