Mishimoto radiator in...
Discussion in '94-95 Talk' started by The Green GT, Sep 21, 2007.
  1. The Green GT No 13 year olds are safe around me.
    Jan 8, 2006
    Message Count:
    3,438
    68
    I finally got around to putting it in. It went in easy. Its thicker so it is a little har to get in, but nothing too bad. The only problem I had was that the part that the part on the drivers side of the radiator that goes through that bracket was a HAIR off, so I had to force it, but after about 10 minutes I got both bolts down.
    I put one gallon of antifreeze, a gallon of some of this stuff: [IMG], and a bottle of watter wetter. I havent gotten to take it out in the heat yet, but so far its staying cooler than it did.
    Heres a pic of the stock rad VS the Mishimoto. Its DEFINITELY not an OEM replacement.
    [IMG]
  2. Blackened302 New Member
    Jul 21, 2005
    Message Count:
    1,477
    mine's worked GREAT so far in the hot, humid heat of South Texas. absolutely no complaints!
  3. wytstang Advanced Member
    Mar 14, 2004
    Message Count:
    5,154
    76
    Link doesn't work, looks nice and thick. I can't wait to hear the long term results.
  4. 94-302-vert New Member
    Aug 16, 2004
    Message Count:
    1,951
    I had the same problem with the brackets for the bottom of the radiator...
  5. 5.0 from 95 Founding Member
    Nov 6, 2001
    Message Count:
    751
    My bottom went in the brackets fine, but I had the same problems with the top bracket. It all worked out in the end.
    Paul
  6. Guero New Member
    Oct 12, 2005
    Message Count:
    2,195
    Looks nice!!!! If this would of been out when I got the summit one I would.....Just because I had to wrok a little extra to make it fit!
Share This Page
