moral delema
Discussion in '2.3L Mustang Talk' started by 4bangen, Feb 29, 2008.
  1. 4bangen Member
    Nov 4, 2004
    Message Count:
    144
    Ok guys so heres the deal, As you know I have an 88 tc. Witch in a few months is going to get a full build.
    My delema is what to do? I have a 2.3t to build and if I do it will be as fallows:
    2.5l stroker, balanced and blue printed.
    stock head ported and pollished with big valves
    stinger header, and exaust
    large FMIC
    Gerret or holset turbo
    Mega Squirt engine management
    100hp wet kit
    and a hope and a prayor
    My othere option was brought up when I picked up two gerret t-3's. I can build up a 302 with forged internals and slap both t-3's on it. This build will caust me about $1500 to $2000 more than the 2.3l. though through my reserch it seams that the power gains will be slight. I'm told (and have witnessed) 5.0's having a limit of around 500hp and I dont want to fork out the cash for a dart block.
    So now I'm asking a bunch of 2.3 guys what you all think. do I stay with my beloved 2.3 or make the jump to a v8?
    This is waighing heavy on my mind. and I need guidence.
    Thank you for your input.
    Matt
  2. SILENTCARL New Member
    Feb 15, 2007
    Message Count:
    40
    They both will make about 450 hp or so, and will be about the same weight... So it's all down to personal preference. I vote 2.3L because it is different then all the 5.0s running around out there.
  3. muskrat2.3 New Member
    Jan 23, 2008
    Message Count:
    11
    I vote for the V-8 . just can't beat the rumble of a V-8.
  4. tim_lemmy New Member
    Dec 13, 2007
    Message Count:
    95
    what are the limits of the stock 2.3l? can you run 450hp on that and not blow it within a few months? can you do that on a 5.0? it's not really about preference it's about how long you want the car to last.
    just my two cents
  5. 65ShelbyClone Founding Member
    Sep 9, 2000
    Message Count:
    4,527
    66
    A "stock" 2.3 turbo engine has a fairly high power ceiling. The most widely quoted upper limit on the stock rods is 450rwhp. However, I can think of one person that went as far as 575rwhp before losing the clutch and spinning a bearing. Hell, Matt and Stinger's 'Project Bolt-on" has gone 10s with a 300,000+ 2.3T. Even more is possible with strapped mains and aftermarket rods/pistons/head.
    A stock 5.0 with forged pistons will probably split down the middle at 600rwhp.
    You're in the wrong forum.
  6. 351wcoupe New Member
    Feb 13, 2003
    Message Count:
    1,845
    Very simply put...up to a certain power level (That I haven't found yet) you can't match me dollar for dollar if building a V8. I did it and swapped back to a 2.3 turbo because it was cheaper and faster. If I had a dollar for every $10000 5.0 that runs 11's I could certainly build another 10 sec 2.3.
  7. GIGGLEME26 New Member
    Feb 18, 2006
    Message Count:
    I'D GO WITH A FOUR BANGER, I HAVE A 93 CONVERT. WHICH IS PUSHING 453.7RWHP WITH A ONE OFF CAM AND SOME ECU REMAPPING. NOW I'M THROWING A T3/T4 TURBO WITH A 50 TRIM. ALSO I'M USING A HOME BUILT MEGA SQUIRT. ON A STOCK 2.3 IT'S POSSIBLE TO HAVE 550+HP WITH A STOCK BOTTOM END. DEPENDING ON YOUR DRIVING HABITS. I FORGOT THE COMPANIES NAME, BUT THEY SELL A SH@# LOAD OF RACE PARTS FOR 2.3. I'LL FIND OUT MORE INFO ON THEM AND REPOST AS SOON AS I CAN. GOOD LUCK WITH YOUR PROJECT. POST SOME PHOTOS OF YOUR RIDE.
  8. 65ShelbyClone Founding Member
    Sep 9, 2000
    Message Count:
    4,527
    66
    Dude.
    Caps Lock.
    Turn it off.
  9. 85_SS_302_Coupe it sucks (I know) to be on the receiving end
    Nov 11, 2003
    Message Count:
    6,747
    36
    98
    For 10k i can build you SEVERAL 11 second Mustangs :shrug:
    $500 for an Explorer 302
    $500 or so for a nitrous kit
    $400 or so for slicks
    _______
    $1400 for an 11 second Mustang all day long.
  10. 351wcoupe New Member
    Feb 13, 2003
    Message Count:
    1,845
    Do you disgree that there's a ton of $10k 11 sec cars? I ran a 12.19 with $1200. looking back on that car I could have easily been in the 11's and stay under $1000.
  11. 85_SS_302_Coupe it sucks (I know) to be on the receiving end
    Nov 11, 2003
    Message Count:
    6,747
    36
    98
    Yeah, i guess i would agree, but i don't think the money was well spent. Plus there's a lot of 500hp Mustangs that only run 10s because they're not built to drag race..so i guess there's a lot to take into consideration.
    You can go out and get a no option coupe and gut the interior and trunk, put 4.10s in it and bolt some slicks and skinnies on it, put an Explorer engine in it with a nice cam and full exhaust, and with a 5 speed and driving the life out of it you'll be knocking on the 11s. I guess the cheaper you wanna go you should expect to cut corners on comfort and "daily driverability".
  12. 351wcoupe New Member
    Feb 13, 2003
    Message Count:
    1,845
    yeah thats what I was getting at.
    I certainly agree though. The fastest and closest to stock car I've ever driven was a no options 87 coupe still SD, only mods were timing, gears, complete exhaust and slicks.
Share This Page
