Motor Mounts for a 67 vert
Discussion in 'Classic Talk' started by BDT 1967, Jan 8, 2007.
  1. BDT 1967 New Member
    Jan 31, 2006
    Message Count:
    88
    I have been trying to get some engine mounts for my car for ever. I ordered a set from NPD, Year One, and Dallas Mustang. None of them fit, for some reason 67 verts used different engine mounts than the 67 fast backs and coupes. None of them fit right. I ended up putting back in the old ones out of frustration, they worked for a while but just recently i broke one loading my car onto the trailer. Now i am stuck, I need to know where i can get a set that will actualy work. Summit sells some polly ones part number PTP-6-503 I don't know if they will work or not. I have also read about adjustable ones. Any ideas?????
  2. 65fastback2+2 New Member
    Aug 4, 2003
    Message Count:
    1,239
    can you just replace both and use whatever mount you want?
  3. BDT 1967 New Member
    Jan 31, 2006
    Message Count:
    88
    When i tried that i could get one on, but the other one would not fit. I remember reading somewhere that the mounts were weird on a 67 vert.
  4. Jester67 New Member
    Sep 21, 2004
    Message Count:
    903
    Not just verts you can have this problems on any 67. 67 was a transitional year and there are several 67 only parts. IIRC edbert used some from energy sub on his vert. You can do a search to make sure of the brand but it fixed the problem. When I replace mine, I intend to use the adjustable ones for this and a couple of other reasons.
  5. BDT 1967 New Member
    Jan 31, 2006
    Message Count:
    88
    I didn't know those adjustable ones were that much. 209 is a little rich for my blood. I was thinking more along the lines of 100.
  6. Jester67 New Member
    Sep 21, 2004
    Message Count:
    903
    The other ones are cheaper but the adjustable ones allow you to fit headers and a trans better as well change the CG for the car a little.
  7. 65fastback2+2 New Member
    Aug 4, 2003
    Message Count:
    1,239
    i know my coupe ones take two people to get them on, but they work...
    the way i fixed mine was I drilled a hole through the middle, stuck a 3/4" bolt through each and tightened the bolt down, this squeezed the rubber inbetween a little and allowed for a MUCH better fit and they wont rip...before I did that it took 2 hours to change one, after I did that, it took 10 minutes to do both...
  8. mustangdave My rearend needs a stud and two nuts.
    Feb 26, 2002
    Message Count:
    3,070
    I knew that 67 verts were different, but what is it exactly that makes them different? Oh yeah, nobody makes them, sorry. I got my 67 coupes mounts from Autozone for under $20/pair and had no trouble.
Share This Page
