mustang logos
Discussion in '94-04 V6 Mustang' started by CALIstanggt, Mar 13, 2004.
  1. CALIstanggt New Member
    Jan 21, 2004
    Message Count:
    44
    Granite Bay, California
    does anyone know how to take off the mustang logos on this sides? i wanted to go for a little bit of a cleaner look with the shaved door handels. The logs have a rubber padding underneith them i think but i dint want to pull them off and break them and mess up my paint job...thanks
  2. Paul1944 New Member
    Feb 22, 2004
    Message Count:
    9
    Use a hair dryer to heat the adhesive behind the emblems and slowly pull them off. If the car is a late model, take extra care not to harm the clearcoat. Don't be surprised to find holes in your fenders behind the emblems. The holes are to insure proper location.
  3. SpectorV Founding Member
    Sep 3, 2000
    Message Count:
    1,872
    Florence, Alabama
    use a hair dryer but be cautious not to get the paint to hot it will mess it up, then ease it back with yoru finger nail (make sure you just didnt cut your finger nails cuz htey will be sharp, then SLOWLY pull it back so the letters dont rip just take your time and alot of it and you will be ok, you might need to use something thinner to get the peal started just dotn scratch it, a pro at a paint shop might can get them off for you in no time with no ill effect so think about that.
  4. Double T New Member
    Jul 25, 2003
    Message Count:
    45
    Bay Area California
    Get a knife/flat screw driver and gently pry up. Then get another knife and cut the rubber sticky stuff between the emblem/car. Take your time it should take less than 10 min per emblem.
    A word of caution though... 1. there will be a 1/2" hole that was used to position the emblem in your fender and 2. that rubber padding is like a think version of 3M tape it is actually foam so when you remove the emblem some of that foam tape will stick to the emblem and some to the car
  5. CALIstanggt New Member
    Jan 21, 2004
    Message Count:
    44
    Thanks for the replies.....ill get on that right away
  6. 007 Founding Member
    Jan 29, 2002
    Message Count:
    3,171
    58
    Broke
    I use dental floss and rubbing alcohol. Works great!
Share This Page
