my 4x4
Discussion in '94-04 V6 Mustang' started by katie98v65spd, Mar 9, 2004.
  1. katie98v65spd New Member
    Mar 9, 2004
    Message Count:
    21
    Denver, CO
    this is my first post so be nice....
    so i have a mustang and i am getting pretty tired of the 4x4 stance of it. i am not new to the car scene (my b/f is actually a member here, mustang50v8) and my car is in need of new shocks and struts, and as he tells me, when its time to repair something its a good time to do upgrades. so i am wondering what a good kit is to lower my car a little 1" - 1.5" at the most, just to make it look better, i have heard ebiach is pretty good, but im open to suggestions. also where should i buy this stuff?
    thanks guys!!
  2. Captain_Ron New Member
    May 11, 2002
    Message Count:
    25
    Exeter, MO
    Hey what's up? Depends on how much money you have to spend. If you want to upgrade to better springs, Ebiach is probably one of the best. They cost about $200 or so. I think the best place to buy from is go to Yahoo Shopping and type in Ebiach mustang sport springs in the search box. It will bring different companies that sell the same products with a wide range in prices. That's where I look to find the cheapest price. As long as the company has a good customer rating I would trust them.
    Another thing to think about is what I'm currently looking at. There is an offical ford store I found on the net at www.stangstore.com. They sell a suspension kit that is the same kit used on the 2001 Bullit mustang that Includes Tokio shocks, struts, springs and front and rear sway bars. The kit only cost $340 which I think is a great price for what your getting. It is also a good start for your suspension set up for accessories such as caster/camber plates. They will help you fix your alignment with the new lowered stance of your car. There is a lot more to do but it is a good start.
    Also if you decide you don't like those Ideas, Steeda is an excellent company with very good customer support. Hope I didn't bore you to death, good luck
    Ron
  3. mustang50v8 New Member
    Feb 4, 2003
    Message Count:
    598
    847 Chicago Burbs
    well i was telling her something that i heard, that the springs used on the gt's and cobras were different cause they had to make up for the extra weight of the v8, am i wrong or no? and was that 200 for a spring set or 200 per spring?
  4. Lsredy2kstang Look, I'm special, dammit
    May 13, 2000
    Message Count:
    2,798
    Woodstcock, Georgia
    First off, the GT springs are the same as the V6. They may be a little different of the spring rate but not by much.
    I also aggree to upgrade if you have to buy them anyway. The bullitts or Mach shocks/struts are great for the V6. You can get them for 170 for the set that includes shocks/struts from www.fordpartsnetwork.com
    I am running Steeda Springs and love them. They gave me right over 1" all around!
    The eibachs are good, but they tend to sag after a while. Also they are a drastric drop and you may scrape over everything.
    Welcome to the board and don't be mad if you start getting any leg humper questions?
    If I can be of any assistance let me know.
    LsRed--Moderator V6, SE Forums
  5. Nates02V6 New Member
    Feb 22, 2004
    Message Count:
    21
    hey guys, newb here lol.
    how hard is it to install them steeda springs? anyone know of a guide on the net here i can look at? thanks!
    Nate
  6. Lsredy2kstang Look, I'm special, dammit
    May 13, 2000
    Message Count:
    2,798
    Woodstcock, Georgia
    It is not really that hard, for the front you just unbolt the strut and the caliper then let the LCA down. Them there rears, the shocks then the LCA. It is not difficult but you have to be careful and make sure you put the news one back in correctly.
  7. marvinmycat Founding Member
    Feb 13, 2002
    Message Count:
    1,185
    Buffalo, NY
    And when you lower the LCA's, you don't let the springs shoot though your torso if you don't use a spring compressor.
  8. Nates02V6 New Member
    Feb 22, 2004
    Message Count:
    21
    shoot threw my torso?!?!?!?! ouch.
    cant you just use a jack to preload the springs and them lower the LCA slowly after you unbolt the strut? let the LCA down all the way and the spring energy should be released correct? or at least most of it. not enough to shoot out but maybe just "pop" out?
  9. Lsredy2kstang Look, I'm special, dammit
    May 13, 2000
    Message Count:
    2,798
    Woodstcock, Georgia
    Yes, that will work, you can also get a short section of chain and put through the spring to take some of the energy.
  10. marvinmycat Founding Member
    Feb 13, 2002
    Message Count:
    1,185
    Buffalo, NY
    In my case, I went to lower the LCA in the rear, I had the car jacked up pretty high, and as the LCA came down, the spring seamed to keep a crap load of tension in it. I then jacked the car up even higher, and lowered the LCA even more. By the time I decided this wasn't going to work out for me, my brake rotor was almost touching the ground, the spring was still in its seat not wanting to come out, and the whole situation looked pretty awkward, so I bailed on the idea of doing this on my own.
    Just letting you know that it can be dangerous if you don't know what you're doing.
  11. Lsredy2kstang Look, I'm special, dammit
    May 13, 2000
    Message Count:
    2,798
    Woodstcock, Georgia
    You can also got to Autozone and get a spring compressor. they are free, you just rent them!
  12. marvinmycat Founding Member
    Feb 13, 2002
    Message Count:
    1,185
    Buffalo, NY
    Are they free "free," or does "rent" imply leave a deposit. I forgot about their tool loan program.
  13. Lsredy2kstang Look, I'm special, dammit
    May 13, 2000
    Message Count:
    2,798
    Woodstcock, Georgia
    Yes, just like the rear caliper compression tool that I have sitting in the garage, I rented it for $35 dollars, refundable when i return the tool.
    So in essence, you spend the money and get it refunded when you bring the tool back.
  14. SpectorV Founding Member
    Sep 3, 2000
    Message Count:
    1,872
    Florence, Alabama
    the best thing for you to do is order some fms c springs from www.gefracing.com they call them c springs due to they have a C in their part number they are stiffer rate for better handeling and lower the car 1.1-1.2 inches front and .4 back if you dont cut the dead coil, the rears are made to be cut up to one full coil so you can adjust the height very easy, and it only takes a couple min to cut the coil off so its not a hard thing to do. I have had the above springs for a year now adn they are great, ride is good, handeling is good, drop is good i left off my top front isolator and cut 3/4 coil on the rear and i am now 1.3 lower front and 1.0 lower back than stock if you want to go measure to see, get on a flat surface and measure from the ground up to the top under side of the fender, stock will be 28.25 inches i am now at 27.0 in the front and 27.25 rear. as far as shocks and struts the mach one tokicos are a very good deal 180-200 shipped for all so definatly check that out, go to www.v6power.net adn ask in the suspention section for a link to where to get them cuz i dotn remember. I am saving up for bilstiens (definatly the best out there in shocks and struts) but they are 540 ~ a set :(
  15. Lsredy2kstang Look, I'm special, dammit
    May 13, 2000
    Message Count:
    2,798
    Woodstcock, Georgia
    I believe the site that Spector is referring to is www.fordpartsnetwork.com They have the Tokicos for 180 for the set of four.
  16. katie98v65spd New Member
    Mar 9, 2004
    Message Count:
    21
    Denver, CO
    Thank guys!! You are all really helpful. Now I gotta decide if I wanna put the $ into this car or save it for the cobra I wanna get in a few years. Hmmmm. I'll let you all know! :nice:
  17. Xanax New Member
    Mar 13, 2004
    Message Count:
    115
    Springs
    Katie just order a Eibach Pro Kit it will kill 4x4 look quick! :nice:
  18. Mach428 New Member
    Dec 8, 2003
    Message Count:
    326
    You also might want to look at www.summitracing.com their service has been great and they have a good selection of parts
  19. CarlsV6 Founding Member
    Sep 27, 2001
    Message Count:
    401
    Stafford, VA
    I used Steeda Sport Springs (some argue they're the same as ford c springs, no one really knows) And bullitt shocks and struts on mine. Pretty good setup, gave a decent stance and didn't compromise ride quality too much. Also no alignment issues, any lower and I'd need caster/camber plates.
    Installation was a snap, there's a pretty good article in the tech section of mustangworld. Took me probably two-three hours to do the install on mine.
  20. Xanax New Member
    Mar 13, 2004
    Message Count:
    115
    Springs
    Steeda Sport Springs are also a great choice when lowering
    your stang :nice:
Share This Page
