my SC problems FIXED!
Discussion in 'Saleen' started by ragu1585, Feb 5, 2006.
  1. ragu1585 New Member
    Jul 23, 2004
    Message Count:
    154
    well i went to my local performance shop after taking it to the dealership! The dealer told me that the boost gauge selonoid went out and that there was no loss of power and it was ok to drive around till they got the selonoid in. The performance shop said that there wasnt really a selonoid for it! Well we threw it on the dyno and before we started the first pull, the belt shreds.. ouch. there goes 60 dollars! We got a new belt on and made the first pull.. it made a wopping 202 hp and 250 ft lbs.. got to lookin around and found out the bypass valve :shrug: (i think) was stuck wide open.. pushed it back and made another run! 322 and 337 i think.. so nothin was wrong with the car except that its gettin stuck wide open!
  2. 03s281sc New Member
    Mar 31, 2005
    Message Count:
    245
    i see that you said your belt shred.. is this a ongoing problem for you? I have this problem very often to the point that i can only drive my car locally and i carry 2 belts in my trunk at a time. Ive been to the dealer to many times to remember for the problem but they never fix it... i am very fed up with my saleen.
  3. HazeGray New Member
    May 2, 2003
    Message Count:
    357
    Congrats on finding and fixing your problem. :nice:
  4. ragu1585 New Member
    Jul 23, 2004
    Message Count:
    154
    no its not an ongoing problem, atleast right now.. it was already tore up pretty bad.. i dont think the guy put it on right when he first took it off.. just my thoughts, but the car only had just over 5k miles on it.. my new belt is i think 113 inches.. and was a really tight fit.. another question.. how much boost are these cars supposed to see.. we hook a mechanical guage up when we was there.. it saw about 9 9 1/2 on that.. and i seen right around 9 on my saleen gauge drivin around..
  5. marcus95 New Member
    Jan 27, 2004
    Message Count:
    2,148
    Bro that sucks. You should advertise it as the "Locally driven only Saleen"
    I'm only joking. The dealers are idiots. Call MArk at Performance Autosport and ask him the exact belt length for your 03. Are you running the stock pulley? The pulleys could appear to be all lined up at a glance but if they are even mis alignend even by a hair they will throw the belt. Also, belt size, stretched belt will cause it. When you get it fixed you will enjoy your car again. I know it sucks that every damn time you take your car out in the back of your mind you can't enjoy it cause you are waiting for the belt to give.
  6. marcus95 New Member
    Jan 27, 2004
    Message Count:
    2,148
    Congrats on your new numbers. 9 lbs of boost is very good on the stock set up.
  7. 03s281sc New Member
    Mar 31, 2005
    Message Count:
    245
    No i do not have a pulley and it still shreds, i know it's not b/c the belts are old or stretched b/c even the brand new saleen brand belts shred and they shred worse than the advance auto belts. The car has shred around 8 BRAND NEW belts, the problem really sucks.
  8. LeenS281 New Member
    Jan 13, 2006
    Message Count:
    33
    Check the Tensioner/pulley.... Ever take a water pump/idle pulley or anything else out with it when it shreds???
  9. 03s281sc New Member
    Mar 31, 2005
    Message Count:
    245
    nope, just shreds the belts, thats it, i was thinking the tensioner but the dealer dosent think thats the problem but the last time i was in i got them to order a new one anyway b/c i explained to them nothing else they have done has worked
  10. LeenS281 New Member
    Jan 13, 2006
    Message Count:
    33
    I would try it!!!
    Took out 3 belts...two water pumps and an Idler pulley....nobody had any idea what it was...till i changed the tensioner...then everyone knew the right answer....: :D
    Look at it this way...nothing to loose. I still have the belt in the trunk and the wrenches to change it, but I don't think I'll need them anymore!!! :shrug:
Share This Page
