Name This Plug
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
its on the passanger side with the MAF and HEGO plugs.
http://www.veryuseful.com/mustang/tech/engine/images/mustangMainHarness.gif
the Tmoss site has the fuel pump as pink/black blue/orange green/yellow red
mines white/blue black/yellow orange/blue red
AC WOT shut off is 3 wire so thats not it
my harness
quick search and it looks like your fuel relay might actually be under the seat, WOT then? MY 92 WOT is four wire if i remember correctly...
i do have a relay under my seat... well under my carpet since i didnt cut that hole out
i guess i really need to get everything back together and see doesnt work with out it
Not that I'm helping in any shape or form, but doing the AOD to T5 swap in my 93, only 1 of the wire colors matched the diagram for the AOD reverse light/nss plug.
I had found this:
http://www.myrestomodmustang.com/articles/AOD_NSS/aod_nss_harness.html
Which showed which pins corresponded to which wire and was able to go by that. But the actual wiring on the car did not match what was "supposed" to be there.
Ok, not that I'm done not helping, continue on.
