Alright guys got a major problem!!!
I went through my car and fixed all the buggered wiring and yesterday got me a la3 pcm i put it in and the car seem to run fine for a little bit at idle but at about 1500 t0 2000 rpm and would fall on it's face.
I thought it might have been the module on the dist. cause when i went to adjust timing the car would die out when i touched the side of the module the car died out so i tried swapping out modules but no start.
Well i went back out this morning and played with it some and still nothing but when the key is in the accy position the fuel injector are pulsing i have a selinoid going off near the passenger firewall under the hood and a relay under the drivers seat buzzing that is with la3 pcm and will try to start i put the original pcm back in and nothing no spark to the coil.
I'm thinking i fried the little brain box on the firewall which i think is my durasapark module so what i'm thinking seeing how 88'tbc don't have it and it's in the coputer i need to change some wiring some where!!!!
Is there a difference in wiring?? If so does anybody here have that?
Also this guy had a superchip installed and i'm assuming this is why the plug coming off of the dist. module the wire are all black and are spliced into the regular wires that would go in to that plug also eliminating the spout connector.
Also what do i need to do to get rid of the boxes and clean up the wiring more under the hood???
