need help
Discussion in 'Mustang Sound & Shine All' started by nicut187, Aug 16, 2007.
  1. nicut187 New Member
    Aug 16, 2007
    Message Count:
    :bang: i need some help.......my stock stereo or radio..whatever u call it...it comes on but no sound.....i had a amp an sub hooked up to it and my bro went an started messin with it an he said he touched speaker wire to metal or summin.....so could it be a fuse? or is the whole radio screwd up?
  2. ChingonStang New Member
    Sep 19, 2004
    Message Count:
    865
    Check the fuses...
  3. Supradude26 New Member
    Oct 12, 2005
    Message Count:
    86
    What he said... ^^^
  4. nicut187 New Member
    Aug 16, 2007
    Message Count:
    what fuses? under the hood? the fuses in the fuse box under the steering wheel all look good............
  5. Infinity Founding Member
    Apr 7, 2002
    Message Count:
    1,250
    What year vehicle, and which stock stereo?
  6. 2002GreyGT New Member
    Jun 10, 2003
    Message Count:
    479
    If you installed an aftermarket amp, does the power light on the amp come on? If not check the the amp as it should have its own fuses (read the manual) check them. If those are good, then check the fuse on the power wire to the amp, should be close to the battery if installed right. Also check the ground wire of the amp. If you have a Multimeter, you can start to take reading form the AMP power wires and follow the wires back and see where the power starts.
    If the amp is getting power, check the speaker wires and speakers. You can take a 9v battery and touch the two speaker wires, one each side, and the speaker should make a small pop sound, if not, the speakers are blown.
    ~K
  7. nicut187 New Member
    Aug 16, 2007
    Message Count:
    year of my car is 98...an im not really sure what kind the stereo is all i knoe is its stock.....an i checked all the fuses yesterday an they wuz all good......and i got sum sound out of it but it juz plays through the rear driver side speaker an thats it......so anybody got any clue to what it is?
  8. snoopeebaron New Member
    Sep 12, 2007
    Message Count:
    Dont know if you still need to know, but reading your post and your brother saying he touched lived speaker wire to bare metal he fried the built in amp on the stereo. From what you said the amp was connected to a sub which would have no bearing on fuses from amp cable or amp itself. You will need to replace the deck ... sorry.
Share This Page
