new dyno Numbers
Discussion in 'Fox 5.0 Talk' started by HO5POINTO1990, Jun 17, 2006.
  1. HO5POINTO1990 New Member
    Aug 12, 2003
    Message Count:
    125
    I just added the whole trick flow kit that goes for 2300 in most auto parts magazines, and I have full exhaust from the headers back with 30 Lb injectors, 70MM TB, 76MM MAF, and my numbers were 272 to the wheels... Has anyone used this kit and have gotten similar dissapointing numbers? I know I have not gotten it fully tuned at a shop, but I have an aftermarket CHIP by Powerdyne or something that I got from jegs.com for 240 and people are telling me I can get 30HP if i get it professionally tuned ????!!!:shrug:
    Just to let you know it comes with the stage one cam, trickflow heads, new rockers and upper and lower intakes. What should i be doing differently?
  2. vikingpower New Member
    Dec 7, 2004
    Message Count:
    677
    That sounds pretty low to me, I got a similar setup and I'm pretty sure it makes a lot more than 270 to the wheels (in comparison to other cars I've driven). I'm gonna get mine dyno'ed sometime this summer as well
  3. fidstang New Member
    Jul 19, 2005
    Message Count:
    315
    Automatic? what type of dyno was it? What was the air to fuel ratio?
  4. Speeds8erM-1 Founding Member
    Sep 6, 2000
    Message Count:
    1,286
    36
    My friend dynoed his 93 Notch years ago with TFS Heads, TFS 1 Cam, GT40 Intake and all the boltons, it only did 276 rwhp. I think the timing was wrong because his balancer was messed up.
  5. 2000xp8 Advanced Member
    Aug 9, 2003
    Message Count:
    4,466
    68
    Too much injector so it was probably rich, Couple that with a c&l, and that's not good.
    Take the chip out, and gently place it in the garbage, foxes with mild mods, and even some with extensive, just don't need a chip, alot of times they make the car run worse, not better.
    What was the timing set at? Should run best around 14-16.
    All tuning is on a fox is timing and fuel pressure, it's not a modular car that is restricted by the computer. Set your timing, drop the injectors to 24's with a pro m, and start the pressure somewhere around 40psi, and you get around 300 to the wheels, which is where is should be.
Share This Page
