New engine won't turn over
Discussion in '2005 - 2009 Specific Tech' started by atv4fun, Jan 10, 2012.
  1. atv4fun New Member
    Jul 20, 2009
    Message Count:
    9
    I've built and installed a stroked 4.6l with a 9.5:1 compression ratio. The build went well until the engine was reinstalled. The engine will not turn over with the plugs installed. It turns over like mad with the plugs out. I've had the battery and starter tested, they checkout fine. I'm running out of ideas and things to check. I'm hoping that someone out there might have some other things I should check. Thanks!
  2. jpplaw Member
    Jan 15, 2009
    Message Count:
    165
    18
    Valves opening?
  3. SpartaPerformance StangNet Sponsor
    Nov 5, 2006
    Message Count:
    1,819
    38
    Long Island NY
    When you say it doesn't turn over what exactly do you mean?
  4. atv4fun New Member
    Jul 20, 2009
    Message Count:
    9
    Yeah, I can only assume the valves are opening, I can watch the cams turning.
  5. atv4fun New Member
    Jul 20, 2009
    Message Count:
    9
    The starter will not spin the motor with the plugs in. It will spin all day with the plugs out. I'm checking now to verify I've got the correct plugs.
  6. SpartaPerformance StangNet Sponsor
    Nov 5, 2006
    Message Count:
    1,819
    38
    Long Island NY
    Sounds like timing may be off, who put the motor together?
  7. jpplaw Member
    Jan 15, 2009
    Message Count:
    165
    18
    Can you turn it over using a breaker bar with the plugs in?
  8. atv4fun New Member
    Jul 20, 2009
    Message Count:
    9
    No it won't turn over with a breaker bar when the plugs are in. With the plugs out I can turn it with a regular 1/2 ratchet, it's not easy but it will turn.
  9. atv4fun New Member
    Jul 20, 2009
    Message Count:
    9
    It's been suggested that I reinstall the plugs, one plug at a time, turning the motor by hand between each plug. When it stops turning that might indicate the cylinder that has an issue. Seems like a logical approach, but time consuming, so it will have to wait for the weekend.
  10. atv4fun New Member
    Jul 20, 2009
    Message Count:
    9
    I went through the whole routine of one spark plug at a time, no change. Rechecked every connection under the hood I could think of. Turns out the problem was electrical vs. mechanical.
    As part of the engine swap I was to relocate the battery to the trunk, so the battery was sitting on a stool next to the car. The jumper cables I was using to try and start the car with just could not pull enough amps to even turn it over, much less start a new tight engine. It dawned on me late Saturday afternoon that this might be my problem, so I dug out some old 1 gauge welding cable I had. When I connected those she started up on the first turn of the key. After the meticulous work building and install the new engine, in the end it’s something obvious or stupid that will trip you up. Oh well stuff happens.
    I’d like to thank everybody for the really great suggestions. I’ll post a link later today to a video we made at the moment of ignition. I won’t be posting all the videos we made of when it didn’t start, way to many of those…lol
    Thanks again!:)
  11. Noobz347 Stangnet Facilities Maint Tech... Er... Janitor
    Jan 5, 2011
    Message Count:
    10,821
    378
    133
    Box behind Walmart
    Are you kidding me??? Really? You were trying to use jumper cables from a battery and you didn't think to mention that? :chair:
    :leaving:
  12. atv4fun New Member
    Jul 20, 2009
    Message Count:
    9
    If I'd thought to mention it, it stands to reason that I would have then considered it a possible problem. Those jumper cables have always served we well over the years.
  13. Noobz347 Stangnet Facilities Maint Tech... Er... Janitor
    Jan 5, 2011
    Message Count:
    10,821
    378
    133
    Box behind Walmart
    :suicide:
    :p
  14. atv4fun New Member
    Jul 20, 2009
    Message Count:
    9
    Video Link:
Share This Page
