Roush New Heat exchanger
I installed a new larger Heat exchanger on my Saleen. After completing the installation and filling the upper Reservoir I turned on the fans and pump. The pump came on but is not moving fluid thru the top reservoir. Does this pump need to be primed and if so does any one know how is it done.
Thanks
Leroy
I have a 03 saleen It has the serries IV blower still has a pump like yours try running the pump and blowing into the coolant tank thats what i did to mine and it primed the pump...
Call Mark at lightningforceperfomance.com(281-385-5339) the one they sell is for a cobra I had to weld some brackets and fittings to make it work not to hard of a job..I'm working with him to see if they will start producing some to fit the saleen using mine as a prototype if you talk to him tell him that you got the info from Marc in California with the 03 saleen it might help get things started...:flag:
