New PMS...idle problems-bad!
Discussion in 'Fox 5.0 Tuning' started by txstang84, Nov 7, 2006.
  1. txstang84 Active Member
    May 21, 2005
    Message Count:
    1,679
    25
    48
    Abilene, tx
    I just got my PMS in the mail today (series II), and tried to hook it up...after zeroing out the previous owners info, I finally got it to start (previous settings had like -68% on startup fuel)...this thing would not idle anywhere below 1500, and it takes a while to settle down to that from 2000 when it first starts...I tried to lean it out a little, i tried pulling timing, i tried slowing down the IAC, I didn't get a chance to lean out the cold comp before it overheated (due to my stupidity-I disconnected my electric fan when I zeroed out the settings, and forgot to reconnect it.)
    any help here would be greatly appreciated. From what I understand my C&L is probably part if not all of my problem, but I talked to Rick at AFM and he said that while it may be a PITA to tune around, it is possible. Anybody got any ideas?
    I followed the instructions on the AFM website for setting the TPS to idle, I set the idle @ 900rpm (IAC disc) and after I was done, the handheld showed idle...it started off before showing "Idle: Pr L." Anyway, I'm scratching my head on this one, I zeroed everything out that I could before puking my radiator all over the garage (so much fun).
    For the time being, I disconnected it, so I can still make it to and from work...guess it'll have to wait till this weekend.
    Thanks in advance guys...
    Year model: 1984
    Engine cubic inch: 302
    Power Adder/NA: NA
    Amount of boost/nitrous:
    Intake: cobra
    Throttle Body: 70mm
    Mass Air Meter: 73mm C&L
    Intake Piping: cold air
    Cylinder Head & rockers: GT-40 + stock '95 Cobra rockers
    Camshaft profile: lunati 51014 284/292 total; 218/226 @ 050; 0.500/ 0.510"
    Injector Size: 19
    FMU type: N/A
    Header size/type: 1 5/8 Mac longtube
    Fuel Pump(s): 155
    Rails: stock
    Supply/Return Line size: stock
    Fuel type: 91 oct
    IDLE Control On/Off:
    fuel:
    timing:
    start-up fuel:
    idle air adjuster:
    Low Load (Fuel first & Timing second)
    2200rpm:
    4000rpm:
    6000rpm:
    7800rpm:
    Medium Load (Fuel first & Timing second)
    2200rpm:
    4000rpm:
    6000rpm:
    7800rpm:
    High Load (Fuel first & Timing second)
    2200rpm:
    4000rpm:
    6000rpm:
    7800rpm:
    WOT (Fuel first & Timing second)
    2200rpm:
    4000rpm:
    6000rpm:
    7800rpm:
    Boost or Tables: (Fuel first & Timing second)
    Max Boost setting:
    @1 psi
    2200rpm:
    4000rpm:
    6000rpm:
    7800rpm:
    @max Boost
    2200rpm:
    4000rpm:
    6000rpm:
    7800rpm:
    Nitrous Tables: (Fuel first & Timing second)
    N20 on
    2200rpm:
    4000rpm:
    6000rpm:
    7800rpm:
    Standalone On/Off:
    Rev Limiter
  2. txstang84 Active Member
    May 21, 2005
    Message Count:
    1,679
    25
    48
    Abilene, tx
    disregard all...I had idle control turned on during tuning, Rick at AFM informed me that they are informing people to get away from that, so...should be good now
  3. Grn92LX Fidanza Man!
    Jan 14, 2001
    Message Count:
    6,627
    76
    New York
    I was gonna post that last night to make sure its off! I shoulda posted..lol
  4. txstang84 Active Member
    May 21, 2005
    Message Count:
    1,679
    25
    48
    Abilene, tx
    no worries bro, I got it squared away, and the cold comp worked 18% cleared it right up-now, I can play with other things!
  5. DigitalGhost New Member
    Nov 10, 2006
    Message Count:
    20
    Portland, OR
    speaking of idling problems, my stock 1990 has been idling at anywhere from 1500 to 2000 off and on. Sometimes it idles that high, sometimes it goes back to normal (under 1k.)
    Anyone know what causes that on a stock 5.0 engine and how to fix it?
  6. LtDavis Member
    Nov 20, 2004
    Message Count:
    69
    PA
    Digital Ghost- I was having idle trouble on mine and replaced the IAC with a 60 dollar NAPA piece. Fixed the idle
Share This Page
