New start up problems, Help!
Discussion in '2.3L (N/A & Turbo)' started by 88convert, Mar 28, 2004.
  1. 88convert New Member
    Jan 17, 2004
    Message Count:
    29
    Indiana
    Ok Guys,
    A few questions. My rebuild started right off the bat, I broke the cam in and now the tinkering starts. Today I had it idling and it was surging about up and down about 500 RPM. I took it down to the corner and back and when I back off the gas to shift (about 3000 RPM) I got this weird rumbling noise. I took it back to the garage and reved it up from the engine compartment to about 3500 - 4000 and got the same noise and it sounded like it came from the K&N down by the front bumper. It is a weird kind of a fluttering noise like the VAM door is shuttering .
    When I free rev it like that it also acts like the valves float or something. It runs rough and dies. If you re-start it and hold the idle up to about 1500 or so, it smooths out again.
    The motor is totaly new. Bored 30 and new everything.
    New ported E6, new T3 turbo, ported and polished head, with stock size valves, Engle 111 cam, Racer Walsh cam gear, ported in-line 4 SVO intake, 35 lb injectors, adjustable FPR, LA3, SVO intercooler, 3" downpipe, 3" straight thru cat, dual 2 1/2 dynomax super turbo cat-back.
    SVO VAM with a remote 3" intake behind the front bumper. All new sensors.
    The valve spring tension was set at 90 pounds closed when I did the head.
    I know with all the experience out there some one should have some ideas.
    Thanks!
  2. latroca1 New Member
    May 1, 2003
    Message Count:
    234
    martinsburg,West Virginia
    The fluttering is the vam door!!! I was getting the same thing when you rev it up and have a lot of air in there and let off it the air has nowhere to go back back to where it came.
    If pull off your K&N and revit up and what not and watch you'll see the little air flapper moving.
  3. 88convert New Member
    Jan 17, 2004
    Message Count:
    29
    Indiana
    What is the cure?
  4. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    A bypass or blow off valve.
  5. 88convert New Member
    Jan 17, 2004
    Message Count:
    29
    Indiana
    Where is a good place to get one? Is this a common problem? I've never seen it mentioned on any of the forums.
    Thanks!
  6. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    www.40bob.com is a good place to start...ebay is another (if you know which units will work).
    Stinger
Share This Page
