now it's a new problem
Discussion in '2.3L (N/A & Turbo)' started by bobaganoosh, Aug 13, 2006.
  1. bobaganoosh New Member
    May 28, 2005
    Message Count:
    71
    flower mound texas
    got the pump seal replaced on the tranny, found out it was replaced already with an 85 gt tranny.
    put the fluids in and if you don't remember my nephew also ripped out the lower radiator hose so when he was towed home.
    so we added the antifreeze and the drove the car around the block, it shifted fine when we started and then as the car warmed up which was pretty quick it started shifting pretty crappy so we added more antifreeze and the temp started to come down but now the tranny is having alot of difficulty shifting into reverse and the rpms get a little high and then the tranny catches in drive.
    what should I start doing
    the front seal didn't leak which was a good thing but I'm not for sure whats going on with the tranny now
    mike
  2. bobaganoosh New Member
    May 28, 2005
    Message Count:
    71
    flower mound texas
    anyone ever had this problem
    mike
  3. bobaganoosh New Member
    May 28, 2005
    Message Count:
    71
    flower mound texas
    okay don't know what happened but my nephew says that the car seems to be running just fine now.
    took a couple of trips for a few miles and now the tranny seems to shifting like normal but he did say that there was a very faint noise the is constant coming from the engine bay somewhere, I starting to think the vacum modulator is needing to be replaced.
    mike
  4. mg man Member
    Jun 25, 2006
    Message Count:
    141
    Check for vacumn at modulator valve. You maybe hearing vacumn leak. Other than that I have no idea other than changing the modulator valve. Good Luck.
  5. BELL Founding Member
    Feb 22, 2002
    Message Count:
    722
    California
    heres a solution:
    unbolt transmission from car
    attach about 100yards of nylon marine rope.
    find a deep lake or a pond.
    drop in water
    presto new boat anchor.
    go to the junkyard get a t-5 and the peddal assy. and just swap it over.
  6. Mr. Rustypwnz Active Member
    Jun 2, 2005
    Message Count:
    1,917
    11
    48
    indianapolis/ valdosta ga
    Amen, them things last forever.
    Josh
  7. 89projectstang New Member
    Dec 14, 2005
    Message Count:
    64
    lol!!! love the anchor! lol, my AOD ran like crap and shifted like crap for a while there, then started to run fine, and then *poof* dead.
  8. bobaganoosh New Member
    May 28, 2005
    Message Count:
    71
    flower mound texas
    I'm waiting for it to blow so I can justify the swap.
    it is my nephews car and he wants a five speed but won't save the money till he has a reason. I would say that not having a car to drive is a good reason
    mike
  9. gdcpony New Member
    Nov 23, 2003
    Message Count:
    Sherrodsville, OH
    Here's a reason; AOD rebuild= $1000. 4cyl t-5 and pedal out of a junkyard= $400. I know where to get the pedal assy, but I took the trans.
Share This Page
